new project
ferp420
Power normally goes through the front wheels,but when needed power is mechanically coupled to the rear wheels.Just like a normal 4wd system,just in reverse.Thats why you can't use 4wd on dry pavement because there is no differential between front and rear, so any turns will bind up the drivetrain.
In a transfer case setup,the subaru transmission is locked in 4wd.The power goes to a transfercase and it is exactly like a normal 4wd system at point.
Edited by Uberoo
ive heard a few people toss the idea around of building a rwd subie for drifting and whatnot, and they always seem to decide that the rear drive is not strong enough. so, are they wrong?
Short answer: No, they are not wrong.
Long answer: using a normal subaru transmission not BRZ,in rwd all power must flow through a small set of transfer gears that arn't really designed to have 100% of the torque flowing through them.Same with the rear suspension and axles.
So a rwd subie for RWD shenanigans is fun but it will blow transmissions and rear axles...
As far as using the BRZ transmission with EJ stuff-It might work.The bolt patterns look similar and probally are because its a subaru, but the starter on the BRZ transmission is opposite to an EJ engine.There might be enough room to make it fit but...
One would need to cut an opening on the drivers side of the bell to mount a Starter in the EJ position.
OR.....
Cut the bell area of the passenger side of the EJ25 to make room for the starter snout.
