ej25dswapquestions Posted September 5, 2014 Share Posted September 5, 2014 i have an ej25d that Link to comment Share on other sites More sharing options...
Dj7291993 Posted September 5, 2014 Share Posted September 5, 2014 If you are asking if it can be done, yes. It's been done several times. The 2.5 is the same procedure as a 2.2, 2.0, or a 1.8. Check out the retrofitting section. Plenty of stuff in there. Also, look for Numbchux guide on the swap. 1 Link to comment Share on other sites More sharing options...
BirdMobile Posted September 5, 2014 Share Posted September 5, 2014 (edited) Loyale2.7Turbo did a 2.7L Turbo... into a Loyale! Edited September 5, 2014 by BirdMobile 2 Link to comment Share on other sites More sharing options...
Prwa101 Posted September 5, 2014 Share Posted September 5, 2014 Yes its been done, but as far as the 25D.... I wouldnt waste my time putting that in just to see it blow up in a hundred miles. If your wanting a 2.5 go with a 251 or 253. 99-02 foresters i do believe, not sure off the top what else they came in, other than just about everything.. haha.. PRWA Link to comment Share on other sites More sharing options...
ej25dswapquestions Posted September 6, 2014 Author Share Posted September 6, 2014 whats bad about a 25d , its just what i already have and its rebuilt w/ 2.2 heads and not the dual cam Link to comment Share on other sites More sharing options...
tizzle Posted September 6, 2014 Share Posted September 6, 2014 I personally don't think there is anything wrong with the EJ25D Link to comment Share on other sites More sharing options...
Prwa101 Posted September 6, 2014 Share Posted September 6, 2014 the 25d has headgasket problems. a 25d with 22 heads is a franken motor completely different they almost make 190hp as long as you run premium fuel, because its a higher compression engine. prwa Link to comment Share on other sites More sharing options...
ej25dswapquestions Posted September 7, 2014 Author Share Posted September 7, 2014 how do i find the Numbchux guide and retrofitting Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 7, 2014 Share Posted September 7, 2014 Check the retrofit forum.. IF you already have 2.2 heads on the 2.5 block all you need to look up is the 2.2 write up. Then hold on tight. Link to comment Share on other sites More sharing options...
ej25dswapquestions Posted September 7, 2014 Author Share Posted September 7, 2014 so i found the numbchux guide and downloaded the pdf. so now im on the search for the 2.2 write up Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 7, 2014 Share Posted September 7, 2014 read through numbchux file first it may be the same thing and I am just thinking funny. It would not be the first time Link to comment Share on other sites More sharing options...
AWD J3wman Posted September 9, 2014 Share Posted September 9, 2014 did anyone notice that OPs name is "ej25dswapquestions" Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 9, 2014 Share Posted September 9, 2014 On 9/9/2014 at 12:14 AM, AWD J3wman said: did anyone notice that OPs name is "ej25dswapquestions" Yes, I noticed that. And the EJ Swap Guide, written by Numbchux is also available in another direct download link that could be found on my "BumbleBeast" build thread, whose link is on my Signature Below... Look at Page five. Kind Regards. 1 Link to comment Share on other sites More sharing options...
ej25dswapquestions Posted October 1, 2014 Author Share Posted October 1, 2014 alright well i have some questions now, i got a 1991 loyale, i was wondering if it has the same body style as a gl 1985 or did they change it at all, i have this really cool pic of one slammed and thats pretty much why i decided to get something like that for the swap , i used to like the legacys more but than that changed , i was also hoping that i could use a digital dash from a gl Link to comment Share on other sites More sharing options...
spazomatic Posted October 1, 2014 Share Posted October 1, 2014 I think you really need to do some reading. I recommend using google, type in your key words, as well as "usmb", and the threads seem to come up easier than using this sites search function. Link to comment Share on other sites More sharing options...
djellum Posted October 3, 2014 Share Posted October 3, 2014 if your talking an 85 gl wagon then it should be the same, they have some cross overs with brats and hatches so be careful with parts in those years. Link to comment Share on other sites More sharing options...
