(tools for) Honing ea engines
Can anybody recommend specific tools for honing the cylinders in ea71 and ea81 engines? I see tools on ebay run from $10 to $150. What do I need to do this, I've got a ea81 block to rebuild with minor corrosion in one cylinder.
Sorry, wrong place...
Edited by Crazyeights
  • 3 weeks later...
the wire wheel type tools for this are the ones I am looking at. ea81 cylinders are about 3.5" in diameter. Do you buy a 3.5" tool? I would think you would want it a little oversized? Also I see them in 240 and 320 grit. So what tool to get? here is a link to the style of tool I am looking at:
http://www.ebay.com/itm/FLEX-HONE-TOOL-GB31224-Flexible-Cylinder-Hone-Bore-Dia-3-1-2in-240-Grit-/221544692867?pt=LH_DefaultDomain_0&hash=item339517bc83
okay I did some more research, 3 3/4" is the correct size, now the only question is what grit, I found these from 120 to 400 grit, I have one cylinder with some corrosion, how course do I need to remove rust and what grit should be used to finish it? Please anyone with personal experience let me know.
