sario Posted September 7, 2014 Share Posted September 7, 2014 Does anyone know where I can buy a front OEM remanufactured axle 97 legacy outback? Or know where i can find the part number? I'm pretty sure I bought one from subarupartsforyou.com last time, but thier website is a lot less intuitive than the last time I vistied it. Link to comment Share on other sites More sharing options...
lmdew Posted September 7, 2014 Share Posted September 7, 2014 http://www.ccrengines.com/mwe/ or re-boot a Subaru axle Link to comment Share on other sites More sharing options...
sario Posted September 7, 2014 Author Share Posted September 7, 2014 I plan on rebooting the axle in the car as a spare. Right now my time is limited, so I want to do the repair quickly. I know the linked axles have a good reputation, but I've bought one from then in the past and the boot tore in under 10,000 miles. The axle I bought had the new CV joint, so stock boots won't fit it. My personal preference is not to buy from them again. Link to comment Share on other sites More sharing options...
idosubaru Posted September 7, 2014 Share Posted September 7, 2014 another option, which is the best IMO, is to buy a used Subaru axle and have a shop reboot it with Subaru boots. www.car-part.com have it and new boots shipped to your mechanic of choice and you've got a one-stop-shop solution for quick repair. probably end up costing less or the same but better end product. probably a step up from random choice but i don't know that Subaru remman is as robust as OEM Subaru axles. Link to comment Share on other sites More sharing options...
sario Posted September 7, 2014 Author Share Posted September 7, 2014 (edited) I know the linked axles have a good reputation, but I've bought one from then in the past and the boot tore in under 10,000 miles. The axle I bought had the new CV joint, so stock boots won't fit it. My personal preference is not to buy from them again. I should have also said my car has King Springs which are probably are harder on boots, and at the very the least voids the warranty on MWE axles. Again ot trying to say anything bad about MWE, I just don't want to go that route again. Edited September 10, 2014 by sario Link to comment Share on other sites More sharing options...
sario Posted September 7, 2014 Author Share Posted September 7, 2014 another option, which is the best IMO, is to buy a used Subaru axle and have a shop reboot it with Subaru boots. www.car-part.com have it and new boots shipped to your mechanic of choice and you've got a one-stop-shop solution for quick repair. probably end up costing less or the same but better end product. probably a step up from random choice but i don't know that Subaru remman is as robust as OEM Subaru axles. I'll definitely keep this in mind. Do you think that OEM subaru boots are going to be better quality than aftermarket ones? Link to comment Share on other sites More sharing options...
lmdew Posted September 7, 2014 Share Posted September 7, 2014 Yes better quality. you can even up grade to the newer plastic style. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 10, 2014 Share Posted September 10, 2014 Yeah, most people report the aftermarket ones failing rather quickly. Link to comment Share on other sites More sharing options...
sario Posted September 10, 2014 Author Share Posted September 10, 2014 Yes better quality. you can even up grade to the newer plastic style. Could you point in the direction of those? I only saw one option for boots on www.subarugenuineparts.com and http://opposedforces.com/parts/legacy/us_b11/type_45/suspension_and_axle/front_axle/illustration_2/ Link to comment Share on other sites More sharing options...
sario Posted September 10, 2014 Author Share Posted September 10, 2014 Does anyone know what years of axles are compatible with a 97 outback? The wrecking yards near me don't seem to have any for 96-99 legacy. Link to comment Share on other sites More sharing options...
idosubaru Posted September 11, 2014 Share Posted September 11, 2014 Try these two tips: 2000+ OBW and Legacy axles also work - just knock the outer tone ring off (tap it off with a hammer) and bingo - it installs just like the original axle.And 2000+ axles have the more robust boots on them, the outer boots have more convolutions and last much longer. If you want those boots - order boots for a 2001 outback. i've never installed these later boots on older axles - sounds like maybe Imdew has? www.car-part.com has billions of axles for $10 - $30, just have some shipped to you. i do it all the time, it's nice having a part sitting on my door step - saves all the time driving, waiting in line, having someone go find the part...or worse yet go remove it...etc. i spend very little time in a store or yard. Alternately - to answer your original question: All 1995-1999 Legacy and Outback are the same. All 1995-1999 Impreza and Forester are the same (and I believe later too - but unsure when they changed). you can search for 1999 impreza axles on ebay, google, car-part.com and see what years also fit that way. do the same for your Outback. of course that won't lead you to the "knock the tone ring off" trick, but will tell you some others that will work. Yes, Subaru boots will last longer. I've been using Beck Arnely boots for years and sometimes they break in 20,000 miles, I'd get Subaru boots unless your time isn't that valuable and you'd rather save $8. Link to comment Share on other sites More sharing options...
sario Posted November 8, 2014 Author Share Posted November 8, 2014 After some really high quotes from salvage yards, I decided I'm just going to buy a new axle. And i Thinking i'm going to try one from a newer outback so i can get the newer style boots. I just want to confirm that a axle for 2004 outback will fit. All i have to do is knock the tone ring off right? Link to comment Share on other sites More sharing options...
