Suba_GL_87 Posted September 9, 2014 Share Posted September 9, 2014 Oil on the air filter and drip of the them.. Oil gone around 3 pints oil.. It's oil pump bad cuz was low psi while driving..? Link to comment Share on other sites More sharing options...
Dee2 Posted September 9, 2014 Share Posted September 9, 2014 You seem to have a bad oil leak somewhere. Leaking oil is being sucked into the air filter. You'll need to find it. Typically it can be on the front end caused by bad cam, crankshaft seals or oil pump gaskets/seal. You're pump may not be damaged by low oil levels but an inspection of the pump may tell more. Link to comment Share on other sites More sharing options...
MilesFox Posted September 10, 2014 Share Posted September 10, 2014 PCV valve 1 Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted September 11, 2014 Author Share Posted September 11, 2014 Thank milesfox! Pcv were old vavle and lose. Thump up! Link to comment Share on other sites More sharing options...
