comatosellama Posted September 10, 2014 Share Posted September 10, 2014 http://imgur.com/7Slevtgwhat is this? And how do I fix the broken wire? Link to comment Share on other sites More sharing options...
jono Posted September 10, 2014 Share Posted September 10, 2014 powered up by IGN circuit, it allows idle speed fuel to flow. It looks the same as one of mine - brittle insulation on wire, gets knocked, snappo. Word is you can buy new after market. Will likely affect your running, won't idle. Helps shut engine off when you switch IGN off. Might be called anti dieseling solenoid Link to comment Share on other sites More sharing options...
comatosellama Posted September 10, 2014 Author Share Posted September 10, 2014 powered up by IGN circuit, it allows idle speed fuel to flow. It looks the same as one of mine - brittle insulation on wire, gets knocked, snappo. Word is you can buy new after market. Will likely affect your running, won't idle. Helps shut engine off when you switch IGN off. Might be called anti dieseling solenoid Can I just solder it back on? Link to comment Share on other sites More sharing options...
DaveT Posted September 11, 2014 Share Posted September 11, 2014 Can I just solder it back on? Not much to loose by trying. Clean it first. Use a new flexible piece of wire. Seal it up with some electrical grade RTV after. Link to comment Share on other sites More sharing options...
BEECHBM69 Posted September 11, 2014 Share Posted September 11, 2014 You can also take it off and gut it. There is a spring and pin inside. Take the pin and spring out, put it back on. Not ideal, but it will get you going until you find another one. (I was unable to find one, but you might have better luck) Dan Link to comment Share on other sites More sharing options...
