Suba_GL_87 Posted September 23, 2014 Share Posted September 23, 2014 My TPS wire became old and It'll going to cut off the wire, because It idles rough. So I've been looking for wire connection of TPS but there is only 3 wires of TPS connection. 1987 suba GL base ea82 FI (cruise control) Any advice? Link to comment Share on other sites More sharing options...
wagonist Posted September 24, 2014 Share Posted September 24, 2014 How many wires does your current TPS have? There are 3 wire, 4 wire, and 5 wire versions around. Link to comment Share on other sites More sharing options...
jono Posted September 24, 2014 Share Posted September 24, 2014 not really sure of the wants of the post - think I am missing some detail ?? , and don't know why you want to cut a wire because you suspect it is the cause of your bad idle ? there is also a 2 wire TPS on NA mpfi EA82 - I have one ! Link to comment Share on other sites More sharing options...
somick Posted September 24, 2014 Share Posted September 24, 2014 We have so many threads for the low idle. Do not mess with you TPS. Make sure you do not have vacuum leaks for starters. Good luck, Sam Link to comment Share on other sites More sharing options...
