1 Lucky Texan Posted September 24, 2014 Share Posted September 24, 2014 Recently tried to re-work a loose rearview mirror on my MIL's Forrester. This thing had been hit or pulled-off before and a different family member tried to fix it. I THINK there is a plate stripped out in the mount adhered to the windshield. Looks like it could slide or pop out for replacement. Opposed forces may not have a diagram for this but I admit I just may not understand what top-tier heading it would be under. kinda like to have the part number for that plate and also the 2 screws that go into it. I suspect it is built to disengage easily in an impact. I managed to get it re-mounted with some aluminum foil wrapped around the screw's threads and some tread locker - but it felt like only one screw is 'biting' so - I want to be prepared to do it correctly. any help with links to diagrams/part numbers appreciated. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 24, 2014 Author Share Posted September 24, 2014 must have been a common problem, I found this; ***** NUMBER: 15-167-13R PART INFORMATION A new Service Kit has been released for this type of repair. Part Number H501SSA042 contains all the mounting hardware necessary to complete the vast majority of these repairs. The kit includes a newly designed cam plate, spring, and two mounting screws. Please note that Mirror Mount Adapter PN H501SSA041 (replaces H501SSA040) now includes this new service kit in the rare event that the Mount Adapter requires replacement or when initially installing an accessory mirror on the above listed vehicle applications. The new Service Kit H501SSA042 contents are pictured below. __________________ Steve ASE Master Tech Subaru Tech 98 Forester ****** Link to comment Share on other sites More sharing options...
somick Posted September 25, 2014 Share Posted September 25, 2014 Did you happen to have any pictures mentioned? Thanks, Sam Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 25, 2014 Author Share Posted September 25, 2014 (edited) the only diagram someone linked on another forum wasn't for this generation Forester. edit; yeah, look around this thread; http://www.subaruforester.org/vbulletin/f88/mirror-falls-off-126869/index2.html Edited September 25, 2014 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
