85 GL fuel relay location
It will be under the dash, behind the fuse panel, and somewhere between there and the steering column. I think all the ea82 relays are in a holder up behind the fuse panel. Hope that helps.
If you do end up needing a new pump, I've got one from my car, just did an ej swap so I won't be needing it.
