Standalone 85/86 Digital Dash
86 Wonder Wedge
Since I'm not sure where to put this, I figured here would be a good place since it'll contain useful information. Also, it's sort of like retro fitting. :drunk:
I'm picked up this beautiful 85/86 Digital Dash from Suberdave for next to nothing, and now that I don't have EA82, I figured it'd be a cool bar decoration.
In the following posts, I'll try to outline it the best I can and/or progress pics.
Enjoy!
  • Like 1
UPDATE: I started looking for pigtails to use so I don't have to cut/modify the cluster in ANY way.
So I went searching knowing that JECS made just about everything for Japanese car makers in the 80s/90s, so I went to my local Pull A Part and started looking at the few 80s stuff they had currently.
After some searching and heartbreak, I found an 89 Civic Sedan (DX) with EFI has the BANG on connectors for the combined/black 16/20 pin and the 20 pin white plug.
Pull the 3 piece plug from the ECU, located below the glove box, under the carpet of the pass. side footwell. 3 down, 1 to go!
  On 9/29/2014 at 10:14 PM, 86 Wonder Wedge said:
...I figured it'd be a cool bar decoration...
Don't Forget to swap the old incandescent bulbs, with multi-tip White Leds,
Those Clusters looks beyond Awesome with them ... :D ... see:
~► http://www.ultimatesubaru.org/forum/topic/69467-ea82-dashboard-backlights-upgrade-to-hid-white-led%C2%B4s/page-6?do=findComment&comment=1156772
Kind Regards.
  • Like 1
Jesek, do you have more detailed pictures of the small device circled in red??
That's the Speedo optical sensor/pickup thing I need to emulate. Where do those wires (or one wire) plug into on the dash? Or do they go into another harness? What about the red/white and yellow wires?
Edited by 86 Wonder Wedge
  • 4 months later...
