SnatchedHatch Posted September 30, 2014 Share Posted September 30, 2014 Found a stock wrx exhaust for extremely cheap with low miles, Would I have back pressure issues using the muffler portion? How would it affect sound? Picture: http://postimg.org/image/vbt3bcgzn/ Link to comment Share on other sites More sharing options...
cal_look_zero Posted September 30, 2014 Share Posted September 30, 2014 It won't work unless you cut the flange off and rotate it to the correct angle. Not to mention there won't be any improvements except maybe a smidge more top end past like 5500 rpm Link to comment Share on other sites More sharing options...
SnatchedHatch Posted September 30, 2014 Author Share Posted September 30, 2014 It won't work unless you cut the flange off and rotate it to the correct angle. Not to mention there won't be any improvements except maybe a smidge more top end past like 5500 rpm I was going for a better exhaust note! I did notice the can is taller, I don't know if it will fit, although given I have the Outback sport, it will until the body squats. Modifying the flange is not a problem, I have to get the OEM muffler cut off as is. Link to comment Share on other sites More sharing options...
SnatchedHatch Posted September 30, 2014 Author Share Posted September 30, 2014 Also looking at this, but given the 3 inch inlet and outlet, http://chicago.craigslist.org/chc/pts/4679517832.html I've heard it will cause loss of low-end power. Others claim that is nonsense and more flow will not affect performance, I hang on the former. What do you think? Link to comment Share on other sites More sharing options...
bratman18 Posted September 30, 2014 Share Posted September 30, 2014 It'll fit fine other than modifying the flange. I did it on mine. It gives it a deeper tone. Link to comment Share on other sites More sharing options...
idosubaru Posted September 30, 2014 Share Posted September 30, 2014 i've put large exhaust on older generation subaru's and noticed a loss in low end above 2.25" on 145 hp XT6's. no experience with newer stuff except that they seem to loose power when the exhaust falls off due to rust! i've driven an H6 and EJ around for awhile without a muffler and converter and they seem to loose some low end unless it's just the noise confusing my butt dyno!! Link to comment Share on other sites More sharing options...
idosubaru Posted September 30, 2014 Share Posted September 30, 2014 (edited) if you can modify though and don't care about cutting and welding then you can basically do whatever you want. be nice to get one of those stock systems - they're made of high quality pipe that can take winter beating in our areas and not rust out as soon. Edited September 30, 2014 by grossgary Link to comment Share on other sites More sharing options...
SnatchedHatch Posted October 1, 2014 Author Share Posted October 1, 2014 The system had an I.D. of 2.5", sooo I hopped on it. $80 for a low mileage WRX muffler with the mid-pipe sectioned resonator? Called a muffler shop I hadn't used in years, the owner turns out to be a Subie fanatic, trying to sell me his RS rims with Carbide studded winter tires This ride is quickly headed toward /r/Battlewagon The muffler is similar in size/shape and the brackets are almost identical.. can't wait to see what happens. I do prefer the OE quality build, I'll have to see about having it put in so as to fully utilize that.. having it done properly if possible. Thanks guys, but I got this one haha Link to comment Share on other sites More sharing options...
SnatchedHatch Posted October 9, 2014 Author Share Posted October 9, 2014 Soo the 2004 WRX cat back OEM set-up is almost bolt-on! Awesome, a new flange is simply needed to mount it past the resonator, in the forward direction. Hangers might need slight adjustment, but the shape and size is spot on. I have a fellow OBS rider from the Chicago area that commented he'd like to buy my stock muffler as his was basterdised. I agree, his magnaflow sounds raspy and crappy :/ I'll be selling him the muffler and midpipe with resonator piping, all unbolted, stock, and with some light surface rust. It's in perfect shape, I'm just replacing mine as the thread suggests. How much should I charge? Labor and fab/parts for replacement on my end is about $100, everything considered. Link to comment Share on other sites More sharing options...
