Sapper 157 Posted September 30, 2014 Share Posted September 30, 2014 (edited) Ok so I would just like to know if there are any cheap or simple improvements that can be made to my car (1984 GL Wagon 1.8L) to increase the MPG. I have already discovered that keeping my tires inflated can improve my mileage by a good 1-2 MPG, but would like to know if there was anything else I can do to improve it. Along with that, are there any improvements that can be made to better the get-up-and-go power of my engine? I know these are kinda to different things but instead of creating two different topics I figured I would just kill two birds with one stone and ask in just one thread. Any suggestions? Edited September 30, 2014 by Sapper 157 Link to comment Share on other sites More sharing options...
rdweninger Posted September 30, 2014 Share Posted September 30, 2014 There's not a lot of performance gains to be found on the 1.8 OHV. A Weber carb may help with fuel delivery coupled with an EA82 intake manifold. I would start with a compression test to see what you are working with. Use ONLY NGK plugs. Check plug wires with ohms meter and/or replace if old. Check for vacuum leaks. Link to comment Share on other sites More sharing options...
sumoco Posted September 30, 2014 Share Posted September 30, 2014 If you're a little ambitious you could install and HHO generator, It's not entirely simple, but it would only take a day or two to create and install, it's bumped my pony power and has consistently gotten around 40-43mpg, and I only have a small generator Link to comment Share on other sites More sharing options...
spicypeanut Posted September 30, 2014 Share Posted September 30, 2014 Something like this? http://www.amazon.com/Super-Hydrogen-HHO-Generator-Kit/dp/B00COSC04K Does this actually work, is it safe to use on a carb'd motor? Or a turbo? Damn so many questions bouncing around in my mind right now. Link to comment Share on other sites More sharing options...
sumoco Posted September 30, 2014 Share Posted September 30, 2014 Exactly like that, research it a little, there's an insane amount of information. When I get home I'll post the links I've found to be the most helpful. Link to comment Share on other sites More sharing options...
MilesFox Posted October 1, 2014 Share Posted October 1, 2014 What ol do you use. Consider a 0w40 over 10w40 to free up some rolling resistance in the engine. Use 75w90 synthetic or semi syn in the front and rear diffs. IF manual trans the fluid MUST be 'synchromesh' or 'extra-s' that has a gl-5 rating Link to comment Share on other sites More sharing options...
bratman2 Posted October 1, 2014 Share Posted October 1, 2014 I prefer Redline MT90 myself. But anyways doesn't hydrogen, if that is what the HHO eludes to be, take a crap load of energy to produce? Link to comment Share on other sites More sharing options...
wallaby Posted October 1, 2014 Share Posted October 1, 2014 5 speed, and a block under the accellerator pedal, get a quiet exhaust - then you won't stomp the throttle to hear it roar..... driving habits are the best way to get more mpg's - i can never do it.....too much of a revhead... 1 Link to comment Share on other sites More sharing options...
MR_Loyale Posted October 2, 2014 Share Posted October 2, 2014 No jack rabbit launches, coast to a stop rather than gassing and the braking. Link to comment Share on other sites More sharing options...
apintonut Posted October 2, 2014 Share Posted October 2, 2014 I too have had good success's with hho but me saying this open a can of warms some say it didn't work make you own opinion by playing with it but I've seen 75mpg's on non Subaru car and truck from 8mpg to 21-27 depending on driving condition and style...... Or convert to propane and have done with it or diesel engine Link to comment Share on other sites More sharing options...
djellum Posted October 2, 2014 Share Posted October 2, 2014 If you're a little ambitious you could install and HHO generator, It's not entirely simple, but it would only take a day or two to create and install, it's bumped my pony power and has consistently gotten around 40-43mpg, and I only have a small generator Hay, Ive been looking into this for a while, Id love to see/hear how you set yours up. I have seen a ton of online stuff and would love to talk to someone who has actually built/used it. I have metal working tools and welders so I can build it fairly easy. you can PM me here. Link to comment Share on other sites More sharing options...
joe5 Posted October 2, 2014 Share Posted October 2, 2014 If you're a little ambitious you could install and HHO generator, It's not entirely simple, but it would only take a day or two to create and install, it's bumped my pony power and has consistently gotten around 40-43mpg, and I only have a small generator I would love to see a write up on this Link to comment Share on other sites More sharing options...
coronan Posted October 2, 2014 Share Posted October 2, 2014 (edited) Care full with HHO. I tried it on my toyota and it ended corroding sensors and valves in my intake manifold. Bench test and filter, Filter FILTER. Edited October 2, 2014 by coronan Link to comment Share on other sites More sharing options...
coronan Posted October 2, 2014 Share Posted October 2, 2014 Also, Maintenance, & Tuning, Don't hot rod it if its not running perfect. Zero vacuum Leaks! Then all of the racer tricks. Headers, Larger exhaust, Cat delete or new cat, High flow muffler. Keep your exhaust tip to 2" so you don't get drone. By the time the gas gets there it will have cooled condensed, and not need large diameter. Index spark plugs, side gap spark plugs, Clean Intake manifold. Port Match Intake and exhaust. (these things are free HP) Link to comment Share on other sites More sharing options...
naru Posted October 2, 2014 Share Posted October 2, 2014 Keep the windows rolled up to reduce drag. Drive like a granny.. Link to comment Share on other sites More sharing options...
jono Posted October 2, 2014 Share Posted October 2, 2014 I asked similar question of how to get more go from EA81 some 15 years ago, and got that there was not much at all you can do - from a Subaru specialist workshop. They ended up selling me twin Hitachi inlet manifold and carbs - these helped once I kitted them out and on a rebuild with oversize pistons and everything fresh. Highest octane fuel has made a difference with my EA82T - from 10 litres per 100km down to 8.7 litres per 100km on highway A cheap and cheerful for EA81 I found was to fit up the exhaust Y pipe from an EA82 , bigger outside diameter pipe, so must be bigger inside the second pipe inside as they are twin tubes. I got an extra 10kph out of third gear, got more torque feel so figure it is gonna give better economy, pretty sure it did give better fuel economy with other EA81 same EA82 Y pipe.. Seen hydrogen kit ~ $200 did nothing but spill white powdery stuff about the joint under bonnet of keenest hydrogen convert out. never revisited that concept again .... Link to comment Share on other sites More sharing options...
apintonut Posted October 3, 2014 Share Posted October 3, 2014 Every thing I know about hho I learned form YouTube user theoriganelunclenemo (spelling)? Link to comment Share on other sites More sharing options...
djellum Posted October 3, 2014 Share Posted October 3, 2014 I have a carbureted car, mainly where did you plumb it into? random vacuum plug, Pcv outlet, carb? Link to comment Share on other sites More sharing options...
wagondragon Posted October 4, 2014 Share Posted October 4, 2014 I'm very interested in this... if it works. I would love to see a video of it in action from someone on usmb. How do you get the fuel mixture right? Also doesnt it put a drain on your battery / alternator? Link to comment Share on other sites More sharing options...
sumoco Posted October 4, 2014 Share Posted October 4, 2014 It does, and I will do a write up on it when I have some free time from work, but what some people have done is fab another alternator bracket, or if you have ac you can delete the ac and put another alt in its place, same with power steering Link to comment Share on other sites More sharing options...
sumoco Posted October 4, 2014 Share Posted October 4, 2014 It does work but it requires patience and trial and error Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted October 5, 2014 Share Posted October 5, 2014 another good way to get more power and mpg is to install a good cold air intake, or intercooler in my case. with my engine running cooler than ever before and not getting hot sometimed it gave me an easy 5mpg increase Link to comment Share on other sites More sharing options...
sumoco Posted October 6, 2014 Share Posted October 6, 2014 Something like this? http://www.amazon.com/Super-Hydrogen-HHO-Generator-Kit/dp/B00COSC04K Does this actually work, is it safe to use on a carb'd motor? Or a turbo? Damn so many questions bouncing around in my mind right now. http://www.hydrogen-first-aid.com/ This website has almost everything that you need to know This guy's build is the best i've ever used, Link to comment Share on other sites More sharing options...
wagondragon Posted October 11, 2014 Share Posted October 11, 2014 How do you get the mixture right for the carb? Link to comment Share on other sites More sharing options...
JuhaKankkunen Posted October 12, 2014 Share Posted October 12, 2014 I get 31,2 MPG last weekend in a road trip, just changing the fuel to shell V Power in my EA81 driving at a speed of 115 km/hand 25 MPG in city drivng. Link to comment Share on other sites More sharing options...
