its_masters Posted October 2, 2014 Share Posted October 2, 2014 I was wondering if a clutch and a flywheel will swap over from a 1998 Legacy Brighton (2.2l) to a 1998 Legacy Outback (2.5l). Link to comment Share on other sites More sharing options...
wtdash Posted October 2, 2014 Share Posted October 2, 2014 (edited) Hi, They should. The 2.2 will be a cable clutch and the 2.5 is hydraulic (hydro),which shouldn't matter. They are both PUSH-type clutches (some turbo models used a PULL-type). Per OpposedForces.com they use the same clutch: Quote Brighton: Clutch P/N: 30100AA620 alternate: 30100AA621 - '96, July — '98, May OB: 30100AA620 alternate: 30100AA621- '95, December — '97, July '96, July — '98, May '97, October — '99, May gl, Td Edited October 2, 2014 by wtdash Link to comment Share on other sites More sharing options...
AdventureSubaru Posted October 3, 2014 Share Posted October 3, 2014 Yep. I swapped over flywheel and clutch from 2.5 to 2.2 when i did the swap on the 99. Same stuff Link to comment Share on other sites More sharing options...
