Another heater question?
My heater fan stopped working back in March, so I replaced the blower relay. Just recently it stopped working again, so I checked the relay but it's fine. Can you guys point me in the direction of a good heater troubleshooting thread? BTW the car is an 86 EA82 wagon. Thanks guys.
Could be a fuse.  Check those.
Could be the relay again... That would be bad luck.
Hook up 12v to the blower motor directly... if it don't run, the motor is shot.
There is also a resistor pack that controls the low medium high fan output.   Those burn out.... but the high setting 'should' always work because it is not resisted.
  • Like 1
  • 1 month later...
Sorry it's taken me so long to get to this. I just tried to hot wire the blower motor by running a power wire and a ground wire from the battery to the plug on the fan motor and got absolutely nothing. I tried with the key on and off and nothing happened. Am I doing this right or am I a complete moron lol?
If you ran power and ground directly to the blower...and it didn't turn.........It's bad.
Sometimes you can pull the end cap off the blower motor itself, and clean out carbon debris and other crud in the brush area.......this will sometimes bring a dead fan back to life.
Otherwise replacement is the option.
Ok, I'm sorry if this has been answered before but I don't really know what to search for so I'm just gonna post it here. My heater blows lukewarm air out the middle vents (possible heater core), but cold air out the sides. What would cause this? It does this on all settings, and my fresh air vents are closed.
Are you sure the vent cable is hooked up correct and actually closing the door on the passenger side?
Also....if you pull and cap the Vac line to the frech air inlet behind the airbox you will get Recirc heat....instead of trying to warm up cold outside air.  (canada models have button/solenoid to do this)
Ok I'll check this weekend, tonight I have to mess with the fan. It's already cutting out again. All the different heat settings work like vent, defrost, bi level ect... it's just blowing cold air from the sides and warmer air out the middle.
