Impreza to Legacy Transmission swap.
   Hey guys:
       Trying to figure out if a Impreza transmission will swap to a Legacy.
Donor:  1993 Impreza AUTOMATIC / Front wheel drive only / 1.8 EJ18
To:    1991 Legacy AUTOMATIC / Front wheel drive only / 2.2  EJ22
   Are the flywheel covers the same on the EJ18 as the EJ22 in this year vintage?
  Would the electrical connectors be the same?
    Thanks for your thoughts.
 Todd
engine and trans will bolt up just fine
the EJ18 intake manifold/TPS sensor (which the transmission uses info from) are way different than the EJ22 electronically.
i'm not sure if that matters...i'd guess it doesn't matter - but clarify that...
instead of swapping the torque converter - you can also swap the flexplate.  i've got an EJ25 flexplate on my EJ18 - so you can definitely bolt your EJ18 flexplate to your Ej22.
i'd guess the torque converters are interchangeable, but just a guess. someone recently saw different torque converters (i'm wondering if it was me on my 03 AT frankentrans this summer?).
