watson524 Posted October 9, 2014 Share Posted October 9, 2014 Still trying to sell the dead 99 SUS. First off, can someone tell me if it's EGR or non EGR? If I'm counting bolts correctly, looks like it's a 4 bolt? Also, can a 99 Forester engine go in it? Link to comment Share on other sites More sharing options...
bratman18 Posted October 9, 2014 Share Posted October 9, 2014 Pretty sure the sus engine is dohc, and the forester is sohc. So, you could use the forester block, and put your heads and intake on it. Link to comment Share on other sites More sharing options...
Rooster2 Posted October 9, 2014 Share Posted October 9, 2014 On 10/9/2014 at 11:39 PM, bratman18 said: Pretty sure the sus engine is dohc, and the forester is sohc. So, you could use the forester block, and put your heads and intake on it. my same thoughts. Link to comment Share on other sites More sharing options...
watson524 Posted October 10, 2014 Author Share Posted October 10, 2014 Yep SUS is DOHC. Thanks for the info. Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 10, 2014 Share Posted October 10, 2014 Nope. Foz 99 is a phase 2 engine. All the electronics are different. Heads are different. Heads are the part you need Right? Didn't yours break the timing belt? Link to comment Share on other sites More sharing options...
watson524 Posted October 10, 2014 Author Share Posted October 10, 2014 Nope, timing belt didn't break, and doesn't look like it jumped time either. We aren't entirely sure what the heck happened but something in the passenger side bank went awry since it'll turn with the key but gets stuck there by hand. Someone interested in buying it was asking me about their Forester engine. Link to comment Share on other sites More sharing options...
Gloyale Posted October 10, 2014 Share Posted October 10, 2014 98 Forrester engine will work. 99+ will not. Link to comment Share on other sites More sharing options...
