Carmen sent a youtube video. You can see the same video at http://www.subaru.com/owners/resource-center/electronics-audio/bluetooth/blueconnect.html
That's what blue connect looks like.
If you don't have that on your center console, then you have regular bluetooth, with which you should be able to hear your navigation directions by connecting it to audio.
  • Like 1
What kind of phone do you have?  You should be able to go into your bluetooth menu on your phone and see what it is connected as.  If you want stuff other than phone calls to come over, it will need to be connected as a media device (on android, apple may call it something else, not sure).  The radio will also need to have it's source on bluetooth audio.  If the radio doesn't have that as an input, you are probably out of luck.
