Hi Guys,
After all reading and understanding about how to lift my car, I decided to do it by my self.
My car : 2006 Impreza SW, 2.0L, 4WD (euro model).
I took my measurements from front and rear strut mounts and they are precise and fit my car perfectly.
The spacers fabricated from 6061 Aluminium.
Attached my drawing in PDF. I also have it in X_T and Solidworks but I cant share it here.
Enjoy,
Arik
Arik Front Spacer.PDF
Arik Rear Spacer.PDF
Nice clean drawings!
If I see it correctly, this is how you fastened the new spacers to the top of the struts:
- drill out the 3 old studs from the top of the struts;
- screw-in 3 M8 screws (threaded on their full length) from the underside of the strut, into the bottom of the new spacer, and tighten-up;
- then insert the exposed ends of the 3 new M8 screws into the car, as normal.
Is that what you did?
Yes, this is what I did.
You don't need to drill the studs, just push them.
The screws are fully threaded, 60mm length, 8.8 grade. I used high strength locktite to secure the bolts in place so they don't get lose when tightening the nuts on the car.
  • 1 year later...
