bobburito Posted October 14, 2014 Share Posted October 14, 2014 So I did a head gaskets new seals had heads machined and checked for cracks ohh and block put everything back together and it started right up timing is dead on engine shakes more than usual motor mounts are new can't achieve over 3500rpm does not idle smooth tomorrow I'm gonna get my compression Guage back and hopefully that might tell me something any ideas would be helpful Link to comment Share on other sites More sharing options...
djellum Posted October 14, 2014 Share Posted October 14, 2014 id double check the timing. these motors can start and run at some pretty amazing timing variances. 1 Link to comment Share on other sites More sharing options...
Subruise Posted October 14, 2014 Share Posted October 14, 2014 check your procedure and repeat. Link to comment Share on other sites More sharing options...
92loyale59 Posted October 14, 2014 Share Posted October 14, 2014 I would say iys timing for sure. I had this happen once . One of the cams probably moved when installing the belt . After you put both belts on make sure the cams are 180 degrees oposite Link to comment Share on other sites More sharing options...
kerandt Posted October 14, 2014 Share Posted October 14, 2014 (edited) I've had a rocker arm roll out of place when mating the cam carrier on. Everything went together but the car ran extremely rough. Compression test found zero on the one cylinder. Anyways maybe you had the same thing happen? Luckily I was able to snap it back in place with only the valve cover off. Edited October 14, 2014 by kerandt 1 Link to comment Share on other sites More sharing options...
bobburito Posted October 15, 2014 Author Share Posted October 15, 2014 found the problem kerandt was right rocker arm came out after the motor sitting for almost 10 years spring was sticky very slow return after cleaning it out and manual crank spins to slow bump start she works great again and another rocker arm tried coming out due to same reasons but stayed in slightly crooked holding valve slightly open but all is fixed thanks for the replies guys Link to comment Share on other sites More sharing options...
bobburito Posted October 15, 2014 Author Share Posted October 15, 2014 so ultimately it was only running on cylinders 2 and 4 my compression test before i fixed it was #1 25psi #2 115psi #3 0psi #4 121psi Link to comment Share on other sites More sharing options...
