Zoom Posted October 15, 2014 Share Posted October 15, 2014 What is involved with replacing this fuel level sensor? This code just popped up on my wife's 2004 Outback base. I know nothing about the sensor (i.e. location of the sensor, ease of replacement, what it will do if it quits all together). Can someone give me a little insight to this? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 15, 2014 Share Posted October 15, 2014 (edited) I dunno what that code points to, but there are 2 sensors in the tank. Take the rear seat out and there are access plates. Good time to inspect/change-out the fuel pump's cap and o-ring, and maybe the fuel filter. http://www.ultimatesubaru.org/forum/showthread.php?t=135288 Edited October 15, 2014 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 15, 2014 Share Posted October 15, 2014 There are two fuel level sensors in the tank. One for each "half" of the tank. This could just be due to corrosion in the wire connector on top of the sensor. There are access plates in the floor on either side just behind the rear seats. Check and clean the connectors first. If the code returns you may need to replace the sensor units. The sensors are only used to drive the fuel guage. The car will NOT stop running if they fail completely, just the fuel guage will stop working. The computer uses a signal from the sensors to determine when to run leak checks for the Evaporative emissions system, which is the only reason this causes a CEL. 2 Link to comment Share on other sites More sharing options...
Zoom Posted October 15, 2014 Author Share Posted October 15, 2014 Is there any way to tell which one is which? Which one is bad, if it is bad? I will check and clean the connectors first but was just curious as to figure out which one is bad. Unfortunately, I need to clear this code to get her car inspected. I just found out that it is overdue. Thank you so much for your help and responses. Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 15, 2014 Share Posted October 15, 2014 The only way to determine which is bad is to remove them and check the contact on the slider for wear. If the unit totally fails you can check it with an ohmmeter for an open circuit, but if the fuel guage still works you won't be able to tell which is bad without removing them from the tank. Link to comment Share on other sites More sharing options...
