SubaruNOOBaru Posted October 20, 2014 Share Posted October 20, 2014 Hello, I am a total rookie at being a gearhead or modding a car. Honestly I just work with computers. But I did see that there are baja mods for 1995 legacy models and I saw a pic of someones modded outback with a Forester suspension. I have googled for parts and don't get the exact years that I am looking for so the things I need to understand are what works with what. If any of you have experience and knowledge on this I would love to get your feedback so I know I am looking at the right parts to invest in so I can put them on my Wagon to make it more offroad and SUV styled. Below is a list of what i have searched out and need feedback on if anyone knows if these will fit my car. PS this is not just for looks for me, I would like this thing to be able to handle going down back roads and use it for living out in the country. Shopping list for my 1995 Subaru Legacy Wagon. 1997 Subaru Forester Suspension Or 1998 Subaru Outback Springs and struts Underbraces, is there something tailored for this model vehicle or is what I found workable? http://www.horsepowerfreaks.com/partdetails/Cusco/Suspension/Under_Braces/Version_II/6993 http://www.horsepowerfreaks.com/performanceparts/subaru/Legacy/Suspension/Lower_Frame_Braces Are 16" wheels too big for this model car even if I am raising it up with a different suspension? http://www.jcwhitney.com/allied-wheel-components-raceline-rockcrusher-series-887-wheel/p3043268.jcwx?skuId=981724&filterid=c3829d1939y1995g2u0j1 I seem to have to have a custom made brushguard since I can't find anything for this car or maybe I didn't google the right terms Quote Link to comment Share on other sites More sharing options...
Uberoo Posted October 21, 2014 Share Posted October 21, 2014 (edited) What exactly is your intention with the car? You said " I would like this thing to be able to handle going down back roads and use it for living out in the country." Unless you find yourself needing more ground clearance the stock suspension will do just fine.These cars are rallied afterall, so the suspension is fairly stout.However, with that being said it might be worth while to pull the carpeting and interior panels to make sure rust hasn't compromised the structure of the car with it being an east coast car and all. I wouldn't worry about under braces per say,and instead worry about putting a decent skid plate on it if it doesn't already have one. Those wheels WILL NOT WORK with yours or any other subaru I know of because they are 8 lug. . I don't have alot of experience with the EJ series cars, so I can't point you toward struts but someone will be along shortly who can help you out on that. Edited October 21, 2014 by Uberoo 1 Quote Link to comment Share on other sites More sharing options...
SubaruNOOBaru Posted October 21, 2014 Author Share Posted October 21, 2014 Uberoo, Thanks for the reply. This car will be traveling back roads time to time. Some of which are just a dirt trail that is in neglect, or even ones that turn in to streams during rainy weather. Nothing like your standard roads. Some of it is rocky and some of it gets torn to hell by larger vehicles using the roads. Is there a better setup for the wheels that I should look into? I don't intend on going mudding but standard road/highway tires I doubt will cut it. Quote Link to comment Share on other sites More sharing options...
Vegablade Posted October 21, 2014 Share Posted October 21, 2014 The wheels you linked to wont fit. The ones you linked to are 8 lug. You will need to find 5x100mm. The suspension you listed should give you a little lift and then just find some smallish tires to fit. I would suggest BF Goodrich T/A KOs or General Grabber AT2s. Size would depend on what size wheel you chose. I would look at a 15" for the best assortment of tires. 1 Quote Link to comment Share on other sites More sharing options...
SubaruNOOBaru Posted October 22, 2014 Author Share Posted October 22, 2014 Good to know on the wheels and tires! Is that all I would need to do or is there anything else I am missing to allow for it to work well in this kind of environment? Quote Link to comment Share on other sites More sharing options...
Uberoo Posted October 22, 2014 Share Posted October 22, 2014 Avoid the factory style steel wheels because they are not strong,either go with alloy wheels(factory or aftermarket) or aftermarket steel wheels.As far as tires go a good set of LT all terrains will work and hold up great for everything you want.Just make sure its an "LT" tire and not P rated,because P rated tires will have weaker sidewalls. Don't forget a skidplate.You can make a stock one off an 80's subaru fit with a little mods, or you can get a super bling skidplate from Primitive Racing for $$$.Some people don't run skidplates because they reduce ground clearance slightly,but if your on a gravel road at speed and you come around a blind corner and there is a rock right there you will be glade you had one.Not to mention when your offroad its nice to not worry about protecting that spot and you can just focus on driving.I have a 87 dodge dakota that I sometimes explore offroad trails with,and the whole time I worry about ripping the plastic front air dam off or puncturing the plastic fuel tank.With a skidplate as long as its not a major impact like a watermelon sized rock at 50 MPH you don't have to worry about it. 1 Quote Link to comment Share on other sites More sharing options...
NorthCoast Posted October 22, 2014 Share Posted October 22, 2014 If you are looking for a cheap and easy upgrade for bombing down gravel roads than go with the struts, factory lift blocks, and rims from an early Outback. It's a direct bolt in vs. the Forester set up. The Primitive skid plate is well worth the money (I have one on my rally car) but for your purposes an old sign would do. For tires you can go up to a 205/75/15 without any clearance issues. Check out this thread for more info. http://www.ultimatesubaru.org/forum/topic/118004-the-unofficial-how-to-lift-your-impreza-thread/ 1 Quote Link to comment Share on other sites More sharing options...
SubaruNOOBaru Posted October 22, 2014 Author Share Posted October 22, 2014 Thanks for that update NorthCoast! That gives me some ideas I can work with Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 22, 2014 Share Posted October 22, 2014 outback or forester struts will give you the clearance you need for bigger tires Quote Link to comment Share on other sites More sharing options...
mthoodsub Posted October 24, 2014 Share Posted October 24, 2014 When I first lifted my Legacy, I used Forester struts and springs. Then I got a set of Legacy Outback struts and springs, and found that the Legacy OB struts give more clearance between tire and spring perch, allowing for larger tires. Also the Forester springs are taller, but can be compressed and swapped over to the OB struts. Eventually I ended up with Legacy OB struts and King springs for a Forester and 27" General Grabbers, but had plenty of room to go with a larger tire. 1 Quote Link to comment Share on other sites More sharing options...
bratman18 Posted October 24, 2014 Share Posted October 24, 2014 When I first lifted my Legacy, I used Forester struts and springs. Then I got a set of Legacy Outback struts and springs, and found that the Legacy OB struts give more clearance between tire and spring perch, allowing for larger tires. Also the Forester springs are taller, but can be compressed and swapped over to the OB struts. Eventually I ended up with Legacy OB struts and King springs for a Forester and 27" General Grabbers, but had plenty of room to go with a larger tire. You must have been using 98-02 Forester struts. The 03-08 has the higher rear spring perch like the Outback struts. And you can put the 98-02 springs on those for a slightly stiffer setup as well. Quote Link to comment Share on other sites More sharing options...
NorthCoast Posted October 24, 2014 Share Posted October 24, 2014 You must have been using 98-02 Forester struts. The 03-08 has the higher rear spring perch like the Outback struts. And you can put the 98-02 springs on those for a slightly stiffer setup as well. or you can use Ironman springs which are half the cost and have a better spring rate than the Kings. Quote Link to comment Share on other sites More sharing options...
Prwa101 Posted October 24, 2014 Share Posted October 24, 2014 or you can use Ironman springs which are half the cost and have a better spring rate than the Kings. There just about the same cost, Subtle wants 399 for ironman springs and Primitive wants 439 shipped for king springs. I run king springs on my forester and i love them! Quote Link to comment Share on other sites More sharing options...
mthoodsub Posted October 24, 2014 Share Posted October 24, 2014 Yes I was using the 98-02 Forester struts. And you mention the 03-08 having a higher REAR spring perch, are the front perches not higher like the OB's? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted October 24, 2014 Share Posted October 24, 2014 Yes I was using the 98-02 Forester struts. And you mention the 03-08 having a higher REAR spring perch, are the front perches not higher like the OB's? The front perches are all the same, pretty much. It's the rears that restrict tire size. Quote Link to comment Share on other sites More sharing options...
ezapar Posted October 24, 2014 Share Posted October 24, 2014 The front perches are all the same, pretty much. It's the rears that restrict tire size. Yeah? 2001 Outback struts compared to 1991 struts. Front. 1998 Outback struts compared to 1991 Legacy. Rear. All said and done. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted October 24, 2014 Share Posted October 24, 2014 Guess I should have clarified. 98-08 forester and 96-99 outback fronts. 1 Quote Link to comment Share on other sites More sharing options...
SubaruNOOBaru Posted October 24, 2014 Author Share Posted October 24, 2014 Wow this exploded but I like the info I am getting! Thanks everyone! Quote Link to comment Share on other sites More sharing options...
Martinie97 Posted February 20, 2017 Share Posted February 20, 2017 Hi everybody, So I wondering if you guys can be of any help to me. I am currently trying to get more ground clearance on my, Subaru Legacy 95 wagon. which is the best way to go? Or how can run bigger tires on it? Thank you, Martin. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted February 21, 2017 Share Posted February 21, 2017 Hi everybody, So I wondering if you guys can be of any help to me. I am currently trying to get more ground clearance on my, Subaru Legacy 95 wagon. which is the best way to go? Or how can run bigger tires on it? Thank you, Martin. Non outback, add outback or forester struts and bigger tires Quote Link to comment Share on other sites More sharing options...
Martinie97 Posted February 21, 2017 Share Posted February 21, 2017 Non outback, add outback or forester struts and bigger tires Okay, what year of forester struts? For the 95 legacy? Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted February 21, 2017 Share Posted February 21, 2017 Okay, what year of forester struts? For the 95 legacy? 1997-2002 Quote Link to comment Share on other sites More sharing options...
Martinie97 Posted February 24, 2017 Share Posted February 24, 2017 1997-2002 Running this set up, I would have to run forester coil springs, correct? Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 6, 2017 Share Posted March 6, 2017 You can swap the legacy springs over but would lose some height. Best is to get a lightly used set of struts/springs as an assembly and just bolt them in. Gives 2-3 inches of lift and you can clear up to a 28 inch tire. I have this set up with some 3/8 HDPE spacers on my 98 legacy and did the same with a 97 Impreza outback a number of years ago. Also helpful but not necessary (Unless you are maxing out tire size) is the trailing arm brackets from a 97-99 legacy outback. Keeps the hub centered in the rear wheel well. Read the sticky at the top for lifting an impreza. Everything on a legacy is identical except the rear tophats will have the same bolt pattern as an outback and wont need drilling. Quote Link to comment Share on other sites More sharing options...
danielhwolf Posted July 10, 2017 Share Posted July 10, 2017 You can swap the legacy springs over but would lose some height. Best is to get a lightly used set of struts/springs as an assembly and just bolt them in. Gives 2-3 inches of lift and you can clear up to a 28 inch tire. I have this set up with some 3/8 HDPE spacers on my 98 legacy and did the same with a 97 Impreza outback a number of years ago. Also helpful but not necessary (Unless you are maxing out tire size) is the trailing arm brackets from a 97-99 legacy outback. Keeps the hub centered in the rear wheel well. Read the sticky at the top for lifting an impreza. Everything on a legacy is identical except the rear tophats will have the same bolt pattern as an outback and wont need drilling. You must have been using 98-02 Forester struts. The 03-08 has the higher rear spring perch like the Outback struts. And you can put the 98-02 springs on those for a slightly stiffer setup as well. Hi, a new member here. I'm researching getting more ground clearance on my '95 Legacy Outback, and this thread confuses me a little bit. Can anyone clarify the following? a. It would seem that the suspension for a Legacy Outback is already a bit higher than a regular Legacy? b. If so, will the Forester suspension (a 97-02 according to this thread) give me additional height? c. And is it still a straight bolt-on? Thanks! Dan Quote Link to comment Share on other sites More sharing options...
