sirtokesalot Posted October 30, 2014 Author Share Posted October 30, 2014 yes it is the ring thats bolted to the back of the hub. i just tried to loosen the bolts and space it closer to the abs sensor witch did help but the issue is still there im probly going to just leave the abs fuse pulled. is there a way to get the abs light to go off on the dash it is currently the only check light lit up in the car. Link to comment Share on other sites More sharing options...
upnorthguy Posted October 31, 2014 Share Posted October 31, 2014 is there a way to get the abs light to go off on the dash it is currently the only check light lit up in the car. A small piece of electrical tape. Link to comment Share on other sites More sharing options...
porcupine73 Posted October 31, 2014 Share Posted October 31, 2014 Not sure on the light short of pulling the bulb, it's probably going to want to stay on pretty bad since that's it's purpose. Or like upnorthguy said ... Link to comment Share on other sites More sharing options...
heartless Posted October 31, 2014 Share Posted October 31, 2014 is there a way to get the abs light to go off on the dash it is currently the only check light lit up in the car. you get used to it after a while - mine has been been on for the entire year I have owned the car - how long before that is unknown... My car has several wheel sensors with the wires broken off right at the sensor (non-repairable) - $100 or more per sensor, and not sure I could get the old sensors out... I pulled the fuse and live with it - brakes work fine otherwise. Link to comment Share on other sites More sharing options...
Dj7291993 Posted November 1, 2014 Share Posted November 1, 2014 not sure I could get the old sensors out... They'll come out, it's just a matter of how many pieces they come out in. Drilling through the plastic isn't so bad, magnet is a bit more annoying. Link to comment Share on other sites More sharing options...
heartless Posted November 1, 2014 Share Posted November 1, 2014 They'll come out, it's just a matter of how many pieces they come out in. Drilling through the plastic isn't so bad, magnet is a bit more annoying. I'm not that worried about it - the brakes work just fine as they are. True, I dont have working ABS, but there are times when ABS is a bigger pain than it is worth... I dont have to worry about inspections where I live, so not real concerned about fixing the problem. Link to comment Share on other sites More sharing options...
Mikevan10 Posted November 9, 2014 Share Posted November 9, 2014 I just scanned this thread. The original brake problem was pulsations when braking, right? You found sticky caliper sliders and remedied that. And the pulsation is now gone? Link to comment Share on other sites More sharing options...
sirtokesalot Posted November 9, 2014 Author Share Posted November 9, 2014 (edited) the abs was causing the real issue the abs tone ting on my car is shot rust has gotten its way with it and causes the abs to activate on the right front whele if i plug in the abs fuse so i dont run the car with the abs fuse in. the brakes dont pulse in my pedal unless the abs fuse is in. this is why my abs dont work right Edited November 9, 2014 by sirtokesalot Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 9, 2014 Share Posted November 9, 2014 I would have to say yes, that is the reason the ABS doesn't work. Are the other tone rings are similar in condition? Link to comment Share on other sites More sharing options...
sirtokesalot Posted November 9, 2014 Author Share Posted November 9, 2014 I would have to say yes, that is the reason the ABS doesn't work. Are the other tone rings are similar in condition? no the front left was in much better shape and the rear passenger one was in very good shape. i never got the drivers side caliper bracket off so im unsure of the rear drivers one. the one in picture is the passenger front. Link to comment Share on other sites More sharing options...
heartless Posted November 10, 2014 Share Posted November 10, 2014 wow - cant say I have ever seen one look that bad, and I live in Wisconsin! that looks like physical damage to me, not just rust... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 10, 2014 Share Posted November 10, 2014 maybe tar? what does it feel like - what's it's composition? I'd start with a cleaning but.....???? Link to comment Share on other sites More sharing options...
1997reduxe Posted November 10, 2014 Share Posted November 10, 2014 look on rockauto for rotos and pad kits, and maybe even rebuilt calipers loaded? i've gotten whole sets of 4 rotors and pads for like 125, they are really cheap now, and rebuilt calipers loaded forlike 25 if they were on clearance. make sure to scroll the whle list that comes up for your car. Link to comment Share on other sites More sharing options...
heartless Posted November 11, 2014 Share Posted November 11, 2014 (edited) considering it is supposed to look like this: I would say there is physical damage. . . Edited November 11, 2014 by heartless Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 11, 2014 Share Posted November 11, 2014 Rust is a beech. Physical damage isn't likely or there would be a definite wear pattern. That's just flaky chunky rust. The deep down, ground-in kind like the catalytic converter flanges get. I would think that whole knuckle was replaced with one from a junkyard car that saw some heavy salt in its day. Possibly was parked in the ocean for a month or so before it went to the junkyard. Link to comment Share on other sites More sharing options...
