barngem Posted October 22, 2014 Share Posted October 22, 2014 (edited) So here it goes. Driving down the road turn a corner go to shift into a gear (manual Trans) 95 subaru outback wagon. nothing happens, acts like I shifted into neutral and wont come out of it. clutch works fine, shifter goes through all gears fine but nothing engages in transmission. No prior trouble and no noise, definatly not the noise you you hear when your transmission goes out. Just sounds like its in neutral. So we get it up on a jack and look. It looks as though something that runs from the shift linkage to the transmission has come out. Anyone have any ideas. I see a lot of mud in this picture we have had a crazy muddy season and I had no idea that the car wash I go through does such a bad job but hopefully someone can see this and give me some input. Do you think this is external to the transmission and can just be put back in an secured possibly a missing clip of some sort? Is there a part missing that holds it in the hole shown? Is it something that has to be re attached inside the transmission which would involve removing the transmission? Any input would be great. New to Subarus always drove Ford Trucks so this is all new. These are the notes taken by my husband to give to Mechanic but we thought if we could fix ourselves we would. The shifter will go through and into all gear positions and feels aswell as sounds like it is engaging correctly. Girl friend says it feelsno different now then when it was working. You can also do same with engine running, no grinding or difference at all. You can rotate the wheels by hand with it engaged in any gear position withno change in resistance compared with doing same rotating while inneutral. The clutch cable and fork and slave cylinder(?) appear to be working same as ever and feel no different in her opinion. Subaru - 1995 Outback - 200K+ - 4cyl - Manual this is what it looks like if it were this is how it looks now unattched attached Any help would be much appreciated Edited October 22, 2014 by barngem Link to comment Share on other sites More sharing options...
Gloyale Posted October 22, 2014 Share Posted October 22, 2014 HOst the pictures somewhere else and/or get better resolution. Cant'see in those. Sounds like maybe a blown cutch disc? Link to comment Share on other sites More sharing options...
barngem Posted October 22, 2014 Author Share Posted October 22, 2014 (edited) Clutch works fine. Any suggestions on what this is that has come unattached. Suggestions about where to host pics maybe photobucket? I tried to cut and paste but it would not let me. The are bigger when you double click but they appear clear to me when I look at them I will try some other way to post Edited October 22, 2014 by barngem Link to comment Share on other sites More sharing options...
barngem Posted October 22, 2014 Author Share Posted October 22, 2014 (edited) Edited October 22, 2014 by barngem Link to comment Share on other sites More sharing options...
Gloyale Posted October 22, 2014 Share Posted October 22, 2014 On 10/22/2014 at 6:52 PM, barngem said: These are the notes taken by my husband to give to Mechanic but we thought if we could fix ourselves we would. The shifter will go through and into all gear positions and feels as well as sounds like it is engaging correctly. Girl friend says it feels no different now then when it was working. You can also do same with engine running, no grinding or difference at all. ....... The clutch cable and fork and slave cylinder(?) appear to be working same as ever and feel no different in her opinion. If the shifter feels and sounds like its moving throught all gears........The it is......If you can feel the detents of each position...the shifter is working and attached......... The fact that you can do that while the engine is running is a clear sign the clutch has a problem, and is not engageing......most likely a sudden delamination of the clutch material on one or both sides..... IF the shifter feels sloppy, loose, and you cant hear the "clunk" of the gears moving when engine off (espescially reverse should be audible).....if that is sloppy no detents felt or engagement heard then it could be the shifter......... can't tell ya....those pics are too hard to see stil for my eyes. 1 Link to comment Share on other sites More sharing options...
greg454 Posted October 23, 2014 Share Posted October 23, 2014 (edited) upload your pictures to tinypic.com Its free. After you upload it will give you the new link for uploading to message boards Just copy that link and then paste it here and your picture should show up. Edited October 23, 2014 by greg454 Link to comment Share on other sites More sharing options...
john in KY Posted October 23, 2014 Share Posted October 23, 2014 Or one of the front CV axles broke. Link to comment Share on other sites More sharing options...
barngem Posted October 23, 2014 Author Share Posted October 23, 2014 (edited) Hello all, I'm the long time BF with some understanding of mechanics. First a big thanks for the replies so far, much appreciated. Please disregard pics and any mention of something pulling out of or back away from the trans case. Initially we had an inadequate jack with car sitting over dirt and could not get a good enough look at things. Once in garage with floor jack and stands and shifter boot loose it was obvious what we saw was the main linkage from shifter to where it enters the trans case. The pics were of same linkage rod so likely not the issue anyway. It appears to be zink plated and drew my eye to the difference of color. To her comment "clutch works fine" I'm going to say the clutch feels and appears to be working, unsure if it's functioning or not. Things are starting to point towards the clutch in my opinion. However, there is no noise or resistance anywhere or anytime, car running or not, wheels rotated by hand, etc.. If the fiber fell off from the clutch disc would it still contact the flywheel? Is there anyway that the pressure plate could have seized in depressed position? The transmission certainly feels and sounds correct in my opinion and hers. Thank you Glowyale for lessening my fear of any internal problems! Further thoughts will be much appreciated. Thanks you for the help provided. Edited October 23, 2014 by barngem Link to comment Share on other sites More sharing options...
Ibreakstuff Posted October 23, 2014 Share Posted October 23, 2014 (edited) Definitely sounds like a clutch issue, they can instantly disintegrate during a gear shift (exceeding facing burst speed limit). It would feel firm then absolutely nothing.A worn disc could also be resting against the pressure plate but not touching the flywheel (clutch dust probably buffers sound also). And pressure plate finger and springs can get broken, but that would be super loud.The only simple thing I can think of is that the clutch cable is not retracting (long shot). Leave it in neutral and visually confirm that the clutch fork moves, while someone presses the clutch pedal.Good luck.Edit: Ahh, I didn't see the part about the cable/fork working ok. I guess that is out, unless its full movement is restricted. Edited October 23, 2014 by Ibreakstuff Link to comment Share on other sites More sharing options...
