scrollwriter Posted October 24, 2014 Share Posted October 24, 2014 I'm trying to find out which tires besides the stock 205-70-15's, will fit and be able to be used on my factory stock 96'outback legacy. I have some 215-65-15's. will they be alright to use??? Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 24, 2014 Share Posted October 24, 2014 As long as the circumference of the tires is within a quarter inch between all four you will be fine. Link to comment Share on other sites More sharing options...
Rooster2 Posted October 24, 2014 Share Posted October 24, 2014 Probably will fit. I have 215 X 70 X 15 size on my 99 OBW, which is the same car that you have. I have no rubbing issues. Car sits a little taller. Just be sure to use the same size tires at all four corners. Subaru AWD requires this. Link to comment Share on other sites More sharing options...
heartless Posted October 25, 2014 Share Posted October 25, 2014 go here: http://www.miata.net/garage/tirecalc.html punch in the stock size and the size you are thinking about using and it will show you the differences. you can switch between side and end (tread) views, and it will also tell you how far off your speedo may be and which way (slow or fast) Link to comment Share on other sites More sharing options...
