Recommended rear springs '86 Turbo wagon
opus
I just slapped on some Loyale shock/spring combination and it looks pretty sharp.  The left side sits about 3/4" lower than the right side.  And you do not want to fully tighten the top bolts until you lower the car off of the jack.  Otherwise it twists the shock shaft when you hit each bump.
