jono Posted October 28, 2014 Share Posted October 28, 2014 Silly me, thought I could just swap out old suspect O2 sensor with a known good one. Not being a turbo, or even a real EA82 - I have an EA82 Y pipe on my EA81 and want to use the O2 simply for monitoring or tune up. Slide underneath armed with a 22mm ring spanner and find heat shield all over the place covering the hex of the O2 sensor. Even if I had a super long 22mm socket, the socket would hit the engine cross member A trial of CRC556 on heatshield bolts and their captive nuts reveals all is not gonna be pretty. I will also need to at leasst drop the pipes off the heads or totally remove to change out this service item. Might just have to snip heatshield a bigger hole ..... Link to comment Share on other sites More sharing options...
Gloyale Posted October 28, 2014 Share Posted October 28, 2014 Bend the wrench Link to comment Share on other sites More sharing options...
Dee2 Posted October 28, 2014 Share Posted October 28, 2014 yup...I just did mine recently and had to remove heat shielding and drop the y pipe to get access to the sensor. It wasn't too bad and everything came free without much trouble. Here's my experience report and help from others. http://www.ultimatesubaru.org/forum/topic/149145-code-32/ Link to comment Share on other sites More sharing options...
DaveT Posted October 29, 2014 Share Posted October 29, 2014 I haven't had an exhaust system with heat shields in a loooong time. Although, the 93 I just got from a guy in CA still has OEM. But I expect that O2 sensor will not come out easily. I'll probably put the all stainless exhaust I made on it when that sensor or the cat fails. It'll be easier. Link to comment Share on other sites More sharing options...
Ibreakstuff Posted October 29, 2014 Share Posted October 29, 2014 There are a few different styles of O2 sensor sockets too Link to comment Share on other sites More sharing options...
ferp420 Posted October 30, 2014 Share Posted October 30, 2014 I just did mine I used a good o2 sensor socket and a shot of pb blaster came out very easy but I already had the exaust off the car Link to comment Share on other sites More sharing options...
kitman Posted October 30, 2014 Share Posted October 30, 2014 My EA82T doesn't got a O2 sensor? Possible? Link to comment Share on other sites More sharing options...
opus Posted October 31, 2014 Share Posted October 31, 2014 My EA82T doesn't got a O2 sensor? Possible? Should be just below the turbo. Link to comment Share on other sites More sharing options...
