bypass O2 sensor?
Remove the computer and throw it away.
You have a weird model that used a computer and some solenoids to alter the mixture by increasing  or decreasing the amount of air allowed to mix with the fuel.
Most of these systems don't work anymore.......and the Car will still run with the ECU unplugged.
And then If you install a weber.......you will be removeing all the stuff that the ECU controlled anyhow.  Ditch it all.
The on;y wire that the weber needs is 12v "key on" power to the electric choke.
