My '94 Loyale: Subaru Utility Wagon
SubaruJawn
in the process of replacing the head gaskets on my loyale..
is there anything i can do (while its out) to increase HP ?
also i plan on chagning the clutch to an XT6 clutch, from what i understand i need the xt6 flywheel and then the xt6 clutch will fit ?
Yes, while it's out throw it away and put an EJ in its spot, voila, more hp!
Just kidding, but changing to an XT6 clutch won't make a difference without the XT6 flywheel, because the flywheel is where you are going to get better throttle response as it is lighter. Obviously change any leaking gasket or seal while you've got the engine out, you already knew that though I'm sure!
  • Like 1
i wish i had everything to throw in an ej22 ! i so would love it..
i know the xt6 is stiffer, as i drive one way stiffer than loyale..
i hope the xt6 flywheel (being lighter) would help me climb hills... 90hp sucks climbing hills
yeah i knew about changing gaskets
i got this kit.
http://www.ebay.com/itm/220699367298?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Nice! Good gasket set for sure. The only other thing I've done is hollow out the cat and I've even built my own Y pipe header before and had just a cherry bomb after the Y then straight out the back and that seemed to help alot, I don't know if you have to pass smog where you live though.
no we dont have emissions tests here, i do have a glasspack on at the end of the stock exhaust system.
as formaking own Y pipe i dont have the skill nor do i have pipe bending tool.
i might knock out the small converter to make it louder..
EDIT:
and its out, saoking in kerosene to clean up all that grease, grime and well you know wha else...lol
Kerosene soaked
well gonna install XT6 clutch, and maybe shave the heads for more power...
what are your guy's thought on shaving the heads?
Edited by SubaruJawn
  On 4/29/2015 at 3:00 AM, machthree2 said:
put a 2.2 in it. obdII will give ya 135 hp. put stainless header and if you don't have smog, take out the cat.
i'd love to install an ej22 but costs so much to make it all work i dont have that kind of money yet, i plan on ej swapping but it will take a long time..
i already have a stainless uel header that i have atleast...lol
Great Job you've done to your Subaru, engine bay looks Clean!
  On 5/6/2015 at 1:14 AM, SubaruJawn said:
... clutch is much stiffer (makes me very happy :D )
I'm glad that you live far away from the horrid Traffic Jams and Steep hills we have in my Country,
Otherwise your Knee would not be that happy...
Kind Regards.
  • Like 1
  • 1 month later...
fun fun fun! nice ride.
i just recieved my adapter plate for the 2.2 swap from PWA101. it came fast , was priced fair , and it looks purdy:)
putting the 2.2 into the dual range 88 wagon. cant freakin wait!
  • Like 1
  • 3 weeks later...
some more work done to scubie
New Blue Headlight bulbs 8000K Extreme Blue
as you can see the passenger is thenew blue bulb, driver is stock halogen.
here is a close up of the extreme blue
night pictures of the headlights (extreme Blue)
New Brake Line hoses, later found the real problem
Some New Hatch supports
works great now :)
stay tuned for more repairs and mods on Scubie
  On 7/15/2015 at 1:40 AM, SubaruJawn said:
...New Blue Headlight bulbs 8000K Extreme Blue
Appreciated SubaruJawn,
Very respectfully let me tell you this, despite that I know that you will not like my advise: Try to avoid driving on Rainy nights with those Blueish lights, the deep blue accent of the light is somehow "Swallowed" by humidity, making to drive on wet pavement with such "illumination" to be pretty Dangerous. Such kind of bulbs are used more for the Looks they give to the car, but they really provides much worser illumination.
Kind Regards.
  • Like 1
  • 2 weeks later...
  • 1 month later...
