naldo Posted October 31, 2014 Share Posted October 31, 2014 Hello guys i have a 05 forester which recently i change the motor on. In the time i have the car it has started to make knocking noise which i think pretty sure comes from the torque converter i am not sure if the rocker arms can make that noise keep in mind that the head where machine shop, but it does the noise when ever i rev the engine or whenever i have the car in reverse of neutral/ stationary at a light. The car runs great shift fine and has no driving problems any idea on what it could be ?? Any suggestions will be gladly appreciated Link to comment Share on other sites More sharing options...
PA Grown Posted October 31, 2014 Share Posted October 31, 2014 Change the oil, add a little oil additive or some automatic tranny fluid and that might clean some gunk out. Idk though that's a hard thing to diagnose over the Internet. ATF fluid is a detergent pretty much and it works great. Link to comment Share on other sites More sharing options...
naldo Posted November 3, 2014 Author Share Posted November 3, 2014 you mean to add tranny fluid to the engine i will try to post a video up of the sound that is making see if you guys can help me out thanks Link to comment Share on other sites More sharing options...
PA Grown Posted November 3, 2014 Share Posted November 3, 2014 Yah add a quart of ATF fluid and use one less quart of oil, obviously. It's a great way to clean out your engine. But replace your oil filter 1500 miles because some of the gunk in the engine will get caught in it and could plug it up possibly, that should quite your engine down if it is the engine. i haven't had any experience messing with Suby transmissions before so I couldn't give you any good advice. Link to comment Share on other sites More sharing options...
TKFlight Posted November 4, 2014 Share Posted November 4, 2014 (edited) Adding ATF fluid to the engine for cleaning? I mean I've heard of it, and I'm not saying you are wrong, but it sounds like a backyard mechanic type thing. My opinion is why would it have detergents if ATF fluid is in a non-combustion environment? You are probably just better off using Auto-RX if you want to do an engine flush, or using a good synthetic oil. For me, tranny fluid stays in the transmission and engine oil stays in the engine. But if he wants to pour it in then he can pour some in, to each his own. Again I am not saying you are wrong I know car guys have their own ways. @naldo; I assume you checked the engine oil level? If the car runs and shifts fine I doubt its the torque converter. From what you are describing it could be piston slap. What type of oil did you put in may I ask? Edited November 4, 2014 by TKFlight Link to comment Share on other sites More sharing options...
naldo Posted November 4, 2014 Author Share Posted November 4, 2014 @TKFlight i put 5-30 what its says on the manual but i know it was regular motor oil it wasn't synthetic motor oil somebody told me that i could be the lifters that need charging and that there is some oil i can buy for that not quit sure if its true or not Link to comment Share on other sites More sharing options...
PA Grown Posted November 4, 2014 Share Posted November 4, 2014 Hey man atf does work man. Gear oil is like 80-90weight and has lots of lubricant and deter green stuff in it to keep the gearbox clean of any buildup of rust or whatever the hell could start building up over the years in a gearbox. Has the same function in an engine cleans and lubricates. Putting in a cleaning agent is the easiest thing to do if it's any engine noise at all and see what happens. Other option is taking out the engine and cleaning the lifters and shim them if they're worn. Oil detergent like Lucas or ATF fluid would be the easiest place to begin at. I had a lifter tick in my Suby I bought a few weeks ago and when I put in clean oil it went away no oil detergent required. An oil change is always the easiest place to start. Good luck Link to comment Share on other sites More sharing options...
S-cargo Posted November 7, 2014 Share Posted November 7, 2014 You might want to make sure that the torque converter bolts are tight. It can sound a lot like a loose rod or piston at acceleration and deceleration. with a recent motor change, it's a possibility. A little time consuming but won't cost anything. Link to comment Share on other sites More sharing options...
MilesFox Posted November 7, 2014 Share Posted November 7, 2014 Dont use gear oil in the engine. IF you think it may be lifter tick by particles or aeration, onsider a 0-wt oil such as 0w40. Knocking sounds cabn be from the torque converter to flex plate bolts being loose, if another motor was installed. Also, a flappy timing belt tensinioner can cause knocking sounds with backlash of the belt. A qt of ATF before an oil change is fgood to clean up sludge. So is using quality synthetic oil such as 0w-40. Often times if a motor is consuming oil, it is from sludge in the oil control rings and crankcase ventilation system, more so than being worn out. The heavy additives such as oil stabilizer are really meant for already burned out and knocking engines (overheated, run out of oil) Link to comment Share on other sites More sharing options...
Txakura Posted November 7, 2014 Share Posted November 7, 2014 My broken drive plate sounded like a rod knock under engine braking. It made a lot of noise on the driver side back of the engine. You could really hear it with the hood up playing with the throttle. Ticks clacks knocks and buzzing Link to comment Share on other sites More sharing options...
