info on how to swap EA82 5 speed hi-low tranny into legacy wagon
Fish-N-Fool
I want to put a older Hi-Low 5 speed tranny out of a GL into a 95 or newer Legacy or Outback subee with the 2.2 motor. What adapter plate would I need and what else is involved to do so?
This is one good option for you. There are many more. I have used this kit for almost 5 years now, not one problem.
http://www.sjrlift.com/index.php/catalog/engine-swap-parts
you will still use the ea to ej adaptor plate . much more is involed and i dont know what that os hah im sure if you search the forum you will find it though . check out anderson design and fab in the products for sale section . or message me . we sell really nice adaptor plate for pretty cheap
In addition to adapter and redrilled flywheel you will need the following
custom length driveline (front section 2" longer.....rumor that 2000-04 Legacy shaft works)
Customized front trans crossmember (drilled to accept EA trans mounts)
Customized shift linkage.....really just retrofitting EA D/R shifter itno place.
Axles.........One of 2 options........
1) run 23 spline inner, FWD, MT 93-94 Impreza axles......only EJ axles to come with a 23 spline inner.
2) open trans.....install a set of 25 spline stubs into the EA D/R......then run pretty much any EJ front axles (I like OE 98-03 Forrester axles)
