Bolt Size for crank pulley
I have a 91 Loyale EA82
Yesterday the crank pulley that runs the alternator & accessories v-belt loosened up and fell off (its the center pulley that connects to same shaft as both timing belts & flywheel).  I have the pulley and belt but I need to figure out the correct bolt size as the bolt got lost ( I know its a 22mm head but i don't know the length, width or thread size). I must have not gotten this bolt quite tight enough when i did the timing belts this summer.
Anybody know the bolt size/type?
Thanks!
  • 7 years later...
  On 11/5/2014 at 4:34 AM, silverback said:
Pitch is 1,75. I do not use a plastic scale for pitch measurements.
Expand
Old post I know but this thread came up in a Google search and was questioned by others discussing it on FB today.
I just checked the crank bolt thread pitch on the original EA82 engine out of my 87 DL and it is without a doubt a M14 x 1.5. I happen to have a metric tap of that size and it threads perfectly into the hole and lines up exact when laid alongside the bolt. I assume other EA82s will be the same.
Edited by azdave
  • Like 2
