PA Grown Posted November 5, 2014 Share Posted November 5, 2014 So my car died last night after bucking and sputtering for 2 miles with me on the throttle giving it hell. So I Turned the key on after it sitting for a day and there was this weird clicking whirring noise in the passenger side under the dash that got quieter after like 20 seconds. It sounds just like a fuel pump pressuring up but it's totally in the wrong place. Died once after starting it up, then I stsrted it again and it idled till warm the whirring clicking noise never went away. So then I started it later yesterday again and none of the same symptoms... What to do? Quote Link to comment Share on other sites More sharing options...
PA Grown Posted November 5, 2014 Author Share Posted November 5, 2014 Clicking whiring noise turned out to be the dying blower fan under the passenger dash... So now idk... The car did the flash the low oil light at me while the car was starting to buck the other night. I just figured it was because the car was bucking so hard. So I'm stuck lol Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 5, 2014 Share Posted November 5, 2014 any dents in the oil pan? maybe blocked or cracked oil pickup. check the oil pressure. there's a port for a real gauge some where. could be something as simple as a bad pressure sender (that thing is designed to light up at some crazy low pressure like 7 psi !) maybe the rear of the oil pump needs re-sealing? Quote Link to comment Share on other sites More sharing options...
PA Grown Posted November 6, 2014 Author Share Posted November 6, 2014 No dents. I'll check the oil pressure this weekend. I always have a valve tick when I first start the car up unless it's overfilled. So yah I suspect a weak sending unit. But it wouldn't make the car buck and it was only 1/2 quart under low. I replaced the fuel filter today and it seemed to smooth out my idle a little and no longer sounds like a v8. And seems to takeoff better and smoother. I'm gonna test my fuel pressure hopefully this weekend, the mechanic I live with has been gone for the last few weeks house sitting a mansion in aspen lol. I'm just curious as to what checklist I should go through to cure the bucking and my car dying. So I'm gonna check oil pressure and fuel pressure, any other tests I should run to try and find a culprit? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 6, 2014 Share Posted November 6, 2014 (edited) no 1 thing that helps the gurus here is accurate info about the symptoms, and anything that may have led to them popping up. next would be any blink codes or OBD codes stored in the computer. Yours has codes even though it isn't OBDII. I've even seen some guys post sound files of noises their car makes. naturally, there are limits to what can be guessed at over the internet. Sometimes, a thread about torque bind or shifting problems will be pages long and the OP will blurt out - "the transmission was swapped 2 weeks ago" or w'ever. sometimes. cars have had rodents nesting in them that chewed-up wires. other times, we get lucky and say, change the knock sensor - they're cheap, and -boom- problem solved. Edited November 6, 2014 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
PA Grown Posted November 6, 2014 Author Share Posted November 6, 2014 Yah I just need to wait for my farms mechanic to get back. I don't know what's up with this car yet. It's too new to me and its got problems in a few areas. I'm crunching for time to drive to Washington for thanksgiving. And freaking out lol. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 6, 2014 Share Posted November 6, 2014 any chance to rent or borrow a car? Might start working on that now. A car like this, new to you, etc. just may not be reliable enough without a decent 'shakedown cruise' close to port. If you know what I mean. check here and maybe you can retrieve some codes from the car; Quote Link to comment Share on other sites More sharing options...
PA Grown Posted November 6, 2014 Author Share Posted November 6, 2014 I can't rent a car yet, and I don't know anyone out here anymore To borrow a car, and I have a warrant for failures to appear so I can't fly either. Between a rock and a hard place lol. Quote Link to comment Share on other sites More sharing options...
heartless Posted November 6, 2014 Share Posted November 6, 2014 1. Take a deep breath, and let it go slowly. 2. go here: http://legacycentral.org/library/literature/codes.htm follow the directions for retrieiving any stored codes - even if the CEL isnt on right now, it may still have something stored. 3. If you do get some codes out of it, post them here so we can help you make sense of them. 1 Quote Link to comment Share on other sites More sharing options...
