ragingbull Posted November 14, 2014 Author Share Posted November 14, 2014 (edited) Ill check the wire for sure.. If it's the coil, I see a Hitachi and Nippondenso options for coils.. Do they both work? Edited November 14, 2014 by ragingbull Link to comment Share on other sites More sharing options...
ragingbull Posted November 14, 2014 Author Share Posted November 14, 2014 Gloyale, you're so right! It's not the coil, I installed a new one, nothing... I checked the wires and they look ok? I put a voltmeter to the first harness/block. It has two red wires and one green one. Im getting power to them. After that it turns into the wiring harness and I have no idea what to do with that.. Where should I start? Link to comment Share on other sites More sharing options...
ragingbull Posted November 14, 2014 Author Share Posted November 14, 2014 Hey can I just run a wire straight from my battery to the ignition coil?? Link to comment Share on other sites More sharing options...
naru Posted November 15, 2014 Share Posted November 15, 2014 Hey can I just run a wire straight from my battery to the ignition coil?? Sure,for testing. You will need to remove it to make the engine stop, Link to comment Share on other sites More sharing options...
DaveT Posted November 15, 2014 Share Posted November 15, 2014 Yes, check that power is supplied to the coil, as above. Other hints: Easy test for no fuel - 1 to 2 seconds of carb cleaner down the throat. Hold gas pedal down about half way. Crank. If it has spark, it will fire for a few seconds, or a burst. If it's very flooded, it may take a try or 2. Check for spark - take the wire from the center of the disty, [other end is connected to the coil] and arrange a spark gap with whatever piece of wire, etc. so you can see it while cranking. About 1/16" gap. You should see a healthy spark. Link to comment Share on other sites More sharing options...
ragingbull Posted November 24, 2014 Author Share Posted November 24, 2014 Finally got her fixed! Turns out it was the ignition module in the disty. . I replaced the whole disty with a brand new one back in August, A1Cardone!! Thankfully it's still under warranty.. Link to comment Share on other sites More sharing options...
