dan595 Posted November 8, 2014 Share Posted November 8, 2014 Hi I have an EA81 motor fitted into my Barchetta 595 . I decided to replace the Hitachi carb with a weber so ordered from the US the redline kit for the EA81 but the adapter plate does not line up with my UK manifold . Does anyone know of an adapter plate that can be used ? The studs on my manifold are approx. 78.5mm and 44mm apart . The ones on the redline #9904.110 are about 7mm different from this . Is there an adapter that can be modded easily ? I was even going to look into having the thing ali welded to the manifold but am not sure how expensive or successful this will be. Maybe someone out there has had the same dilemma . Link to comment Share on other sites More sharing options...
Gloyale Posted November 8, 2014 Share Posted November 8, 2014 Perhaps you ordered the EA82 adapter??? If so, you could just use an EA82 carby manifold. Otherwise welding would be great.....just have it done by someone with experience. Link to comment Share on other sites More sharing options...
dan595 Posted November 8, 2014 Author Share Posted November 8, 2014 I am certain I bought the correct adapter , its part #99004.110 which is listed everywhere as the right part , I can only guess that my ea81 manifold is slightly different for the UK market ? Link to comment Share on other sites More sharing options...
Gloyale Posted November 8, 2014 Share Posted November 8, 2014 Well.....You need a US or other market EA81 mani then huh? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 8, 2014 Share Posted November 8, 2014 I Agree with Gloyale, Welding the Aluminium Adapter to the Aluminium intake manifold is your best and easier bet; I've done it several times, always with great results, you only need to close the water passage that is on the intake manifold, for the old hitachi carb, prior to the welding job; also by welding, you avoid future vacuum leaks due to worn seals between the intake manifold and the adapter plate. Kind Regards. Link to comment Share on other sites More sharing options...
dan595 Posted November 9, 2014 Author Share Posted November 9, 2014 OK many thanks for the input , cast ali welding seems to be the next stage . Thanks again guys Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 10, 2014 Share Posted November 10, 2014 You're Welcome! Would you mind to share a couple of photos of your... ... an EA81 motor fitted into my Barchetta 595 ... ...Subaru powered Barchetta 595, here? Kind Regards. Link to comment Share on other sites More sharing options...
dan595 Posted November 10, 2014 Author Share Posted November 10, 2014 Have a look on the YOUTUBE for Barchetta 595 with Subaru EA81 motor Zcars Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 10, 2014 Share Posted November 10, 2014 Found it ... ... Thank You! Link to comment Share on other sites More sharing options...
dan595 Posted November 15, 2014 Author Share Posted November 15, 2014 The manifold is now with a local firm to me AlloyFabweld , it's not cheap , they want £30 an hour for 3 hours of work . I will post a pic when I have it back Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 15, 2014 Share Posted November 15, 2014 Wow! ... ... that is Extremely expensive, especially if you compare with our Latin American Prices, here people never want anything for an Hour nor any timing, only for the Job done; in fact for welding the same, at an excellent quality shop, I only paid the equivalent of $ 15.ºº US Dollars, in our Currency, the Lempira. Kind Regards. Link to comment Share on other sites More sharing options...
