Everything Works On Reinstalled Tranny Except Speedo
5 speed manual. reinstalled tranny and everything seems to work fine except speedo. all electrical plugs OK.
does not have a speedo cable. is the speedo on one of the plugs? it must be an electrical connection somewhere. this is a 99.
what can I check? thanks.
Speed sensor is on the passenger side about midway back. It has a small black 2 pin plug and its easy to miss when plugging everything back in.
It plugs into the harness up near the other small plugs for the reverse and nuetral switches, but the speed sensor plug is usually hanging down off the bottom of the harness.
