1-3-2-4 Posted November 10, 2014 Share Posted November 10, 2014 I have a '05 Legacy GT and I started getting a misfire on cylinder 2, anyways after checking I pulled the injector connector for #2 and it had no effect at all on the idle.. the injector is no good? I wont be able to replace the injector until tomorrow morning. I will say when I did replace the plugs it was slightly wet. Link to comment Share on other sites More sharing options...
wtdash Posted November 10, 2014 Share Posted November 10, 2014 (edited) Hi, You can check the injectors resistance - should be 10-12 Ohms, I believe, but I'd compare to another 1 or 2 as I'm going off what earlier year side-feed injectors are. But does sound 'dead'. BTW, the side-feed yellows in your '05 are the same as '04-'06 STI, Forester XT, Baja turbo, & Outback XT use. TD Edited November 10, 2014 by wtdash Link to comment Share on other sites More sharing options...
mikaleda Posted November 10, 2014 Share Posted November 10, 2014 Well you narowed the problem down to one cylinder so its going to be either an injector, plug, or wire. I would check the plug and wire just in case, but it does sound like the injector is at fault Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 10, 2014 Author Share Posted November 10, 2014 These idiots at the post office yesterday said I was not home now this morning they are like it's out with the driver.. how they can get by with customer service is beyond me... Link to comment Share on other sites More sharing options...
Bushwick Posted November 10, 2014 Share Posted November 10, 2014 (edited) Before swapping in a new injector, I'd try swapping the injector with a different cylinder (i.e. disconnect, and place over a different cyl, then reconnect with that cyl.'s harness) reset the codes, then see if your misfire code (P0302) follows the injector into it's new cylinder (like a P0301) or stays stays as a (P0302 cyl. #2 misfire). A "wet" plug means it's getting gas but weak spark, or too much gas. Edited November 10, 2014 by Bushwick Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 11, 2014 Author Share Posted November 11, 2014 Changed the injector but it turned out to be a bad coil Link to comment Share on other sites More sharing options...
