Bushwick Posted November 13, 2014 Share Posted November 13, 2014 Was leaving a CVS a mile from home and while making a turn I thought I felt the car surge slightly or something. Looked down and the ABS light was on. Got home, shut it off, then restarted to see if it'd come back. It didn't. Anyways, I'm trying to figure out the best approach to read whatever code it likely stored, though there's too much irrelevant "ABS" crap in the google searches along with contradicting statements, so figured asking was the best bet. Being a 95', can Auto Zone pull the code with their scanner? Or do I have to do some archaic ground connector 6 with key off grumble grumble? If the latter, where is the connector exactly and what pin gets grounded? Does the ABS light flash still initiate with an "11", followed by the code? Thanks. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 13, 2014 Share Posted November 13, 2014 the ABS is very sensitive to voltage too - check your charging system. Link to comment Share on other sites More sharing options...
Bushwick Posted November 13, 2014 Author Share Posted November 13, 2014 Next time I'm out for a drive, I'll rig my voltmeter up to a cig lighter socket and see if the volts drop. Alt is from a lower mileage 11' Tribecca, so I doubt it's bad yet but I'll watch it. Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 13, 2014 Share Posted November 13, 2014 ABS codes can only be read using the ground pin method in the ABS diagnostic connector. There shouldn't be a code for normal system, just what codes are currently in the system. They do have an issue with the ABS motor relays sticking among some other issues which can happen in the scenario that you describe. Only way to know is to know what the code is. Link to comment Share on other sites More sharing options...
Bushwick Posted November 13, 2014 Author Share Posted November 13, 2014 I thought OBDII allowed stored ABS codes to get pulled if the scanner was capable? I don't mind doing the old fashioned way with the ABS light, but I need concrete advice on what pin and what plug before messing with it. It's not in the kick panel. Link to comment Share on other sites More sharing options...
upnorthguy Posted November 13, 2014 Share Posted November 13, 2014 JohnC has this bit over at legacygt: http://legacygt.com/forums/showthread.php/abs-problem-163633.html?t=163633 1 Link to comment Share on other sites More sharing options...
Bushwick Posted November 14, 2014 Author Share Posted November 14, 2014 On 11/13/2014 at 10:39 PM, upnorthguy said: JohnC has this bit over at legacygt: http://legacygt.com/forums/showthread.php/abs-problem-163633.html?t=163633 Thanks for posting that! The abridged version for anyone stumbling into this is "ground pin #3 on connector B82". Another site http://forums.nasioc.com/forums/showthread.php?t=1336307 (post #2) states pin #6 needs grounded as well. Can anyone confirm? It also states pin #6 is needed to erase the stored codes. Does that apply with my Legacy? Here's a crude illustration I found that shows what the connector looks like as it's facing you with the pins numbered: Link to comment Share on other sites More sharing options...
johnceggleston Posted November 14, 2014 Share Posted November 14, 2014 (edited) Quote first, not all locations have wires. my understanding it that each pin, wire, that is there is for a different ''system''. possible systems are TCU - trans codes SRS - air bag codes ABS - anti lock braking codes and all are intended to be grounded. so even if you ground the wrong one, you will not do any damage. you just get the wrong info. i have never heard that you need to ground out more than one pin for any one system, but my experience is limited. i have only checked trans codes. any time i have had another code it was due to improper service , corrected by proper service, (''locking'' the air bag connectors in the steering wheel) or dirt, rust, or crap, on the ABS sensor tip. a trouble light could be caused by a bad ''brain'' or wiring, but the active parts are much more likely. especially if you were just working on the brakes or steering wheel / clock spring/ air bag. if you disturb something and then you get a light, look where you were working. Edited November 14, 2014 by johnceggleston Link to comment Share on other sites More sharing options...
Bushwick Posted November 14, 2014 Author Share Posted November 14, 2014 Thanks for the verification, John. It only came on once, then immediately reset, so hoping it's just excess mud on a sensor or something that blocked off the signal temporarily. Just wanted the verification before anything gets grounded out. Link to comment Share on other sites More sharing options...
bluedotsnow Posted November 15, 2014 Share Posted November 15, 2014 sometimes metal shavings collect on the sensor(magnet) and mess up the reading or mud impeding it Link to comment Share on other sites More sharing options...
upnorthguy Posted November 15, 2014 Share Posted November 15, 2014 As an interesting tidbit I learned about the ABS sensor on my 95 today...apparently the Outback and Legacy sensors are not the same. I messed up one of my front sensors removing it a few months ago. I picked a sensor up at a yard today, but it was from an Outback. I figured they were interchangeable. Not the case. The Outback sensor does not fit into my knuckle (a little too large). I confirmed by looking at Advance Auto...different part numbers for the Legacy and Outback. Link to comment Share on other sites More sharing options...
