Impreza_WRX_STi Posted May 16, 2004 Share Posted May 16, 2004 I just got a 98 OBS 2 months ago. I have had a 93 Impreza for years and have did a lot of maintenance myself. But in the 98 OBS, I am blowing off CYL Misfire #2 codes all the time, do my first instict is to change the spark plugs. Well, both #2, and #4 had the spark plug washer half way against the seat of the spark plug, and the opposite side up about 3-4 notches on the thread. I have changed many spark plugs before, and I have never had a washer skip threads like that. Now I wonder if there is anything I can put on the spark plug seat and the washer? to keep it stuck together until it is tight so that the washer is not moving around while I tighten the spark plug? Max. Link to comment Share on other sites More sharing options...
cookie Posted May 16, 2004 Share Posted May 16, 2004 the plug and it is not a problem. It is not that unusual to have one back off when you remove it. I have seen mechanics lose the washer, jam it on the threads cross threaded and stick it, and crack the plug by torqueing wrong. This just show you can screw up anything if you try. Link to comment Share on other sites More sharing options...
Impreza_WRX_STi Posted May 18, 2004 Author Share Posted May 18, 2004 I wonder if I could put loc-tite between the seat and the washer? I think it could with stand the temps on top of the cylinder right? Max Link to comment Share on other sites More sharing options...
subiemech85 Posted May 18, 2004 Share Posted May 18, 2004 make sure the washer is good and where it belongs, and check the wires and control module Link to comment Share on other sites More sharing options...
NOMAD327 Posted May 18, 2004 Share Posted May 18, 2004 Impreza_WRX_STi said: I wonder if I could put loc-tite between the seat and the washer? I think it could with stand the temps on top of the cylinder right? Max All loctite products break down at 200 degrees which is useful if you come upon bolts that have been assembled with the red threadsealer which is not intended to allow you to unwrench the fastener at a later time. If the washer is threaded on all the way when you start in with the plug it will stay out of the way during assembly. Crushing the washer and torquing the threads is all that's needed to keep the plugs from ever backing out. Link to comment Share on other sites More sharing options...
