shanonsf Posted May 16, 2004 Share Posted May 16, 2004 hey there, got the weber 32/36 DGEV on but have fuel plumbing questions. How do ID which line is which? are 'wet' lines feul-in and 'dry' returns? I've reread Cameron's article but am stuck with the plumbing part. Is there a diagram somewhere that IDs these carb/fuel lines, can't find a image anywhere. Anyone got a good pic of an completed install? thx Shanonsf 82 GLW Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 16, 2004 Share Posted May 16, 2004 There's only 2 fuel lines going to the carb itself. A supply and a return. Both eminate from the little forked hose barb at the float bowl inlet on the Hitachi. Many people remove that barb and install it to the weber. I personally just capped off the return line. Either way seems to work fine as far as I can tell. The rest of the lines on the carb are vacuum lines of one sort or another. EGR, disty, and various emmissions related stuff like evap and purge lines. GD Link to comment Share on other sites More sharing options...
shanonsf Posted May 18, 2004 Author Share Posted May 18, 2004 thx GD, got it all on there and just started pull'd/capp'd off anything that ain't goin' to the weber, right?! also, where does the hot wire go from the electric choke? does it need power or is it a temp sensor type thingy...??? the swap pics from the USMB manuel need a bit more detail for idiots like me. If mine works, I'll snap some pics and P'Shop some detail arrows..... thx gang shanonsf 82 GLW (manipulated) Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 18, 2004 Share Posted May 18, 2004 Hot wire goes to the plug that the Hitachi was connected to. Test the plug to see which one is not. Several of them should be with the key on. GD Link to comment Share on other sites More sharing options...
