stewartkb Posted November 17, 2014 Share Posted November 17, 2014 Has anyone done this replacement before? My AC compressor was having issues on my 81 wagon, and I forked out money for a new one, not a remanufactured. I have heard that most compressors are shipped dry, so they require oil - Which isn't a big deal, I just need some general info on doing a proper install so I don't destroy the system. I also bought a new Receiver Drier / Accumulator and expansion valve, as it's recommended when you replace the compressor. (Warranty also requires it.) So anyone with some helpful tips on this, I'd appreciate it before I get stuff torn apart. Thanks Link to comment Share on other sites More sharing options...
wagonist Posted November 17, 2014 Share Posted November 17, 2014 You're going to need someone to gas it up after you've installed it all, so get friendly with your local AC guy. I've bought seals, receiver/dryers all separately before. They'll prob sell you that stuff no worries, and also give advice. If they just want to do the job only, then find someone else If you've got the system degassed, it's probably a good idea to replace the seals in the lines. Total cost is about $5 if you can do it all yourself and worth it if you've just shelled out for gas & the system doesn't seal. Can be labour intensive cos the joins are often difficult to get access to though. The Loyale has 2 joins inside the condenser box behind the dash, which 99% of the time don't get replaced. Not sure if the earlier models have this same design flaw... Definietely worth the effort to do these also, just a PITA 1 Link to comment Share on other sites More sharing options...
stewartkb Posted December 5, 2014 Author Share Posted December 5, 2014 Thanks for the info wagonist. I think I got everything I need, including new seals! Link to comment Share on other sites More sharing options...
