shanonsf Posted May 16, 2004 Share Posted May 16, 2004 hey all, got the Weber on (32/36 DGEV on ea81) and have some plumbing questions. I've read and seen the pics from the board and still have questions on ID'n which line is which. Are the fuel-in lines 'wet and return lines 'dry'. Also what that about stopping the return line at the firewall??!? Also, I understand theat a feul pressure regulator in needed, true?! if so where does this plumb in?? any help appreciated, I'm half finished here and need help!! thx all, ShanonSF 82 GLW Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 16, 2004 Share Posted May 16, 2004 See your last post on this for the return line thing. I answered it there. As for a pressure regulator, no you don't need one. The reccomended pressure for the weber is 4 psi. The stock pump only puts out 1.35 - 2.06 psi. Thus a pressure regulator is a waste of time. GD Link to comment Share on other sites More sharing options...
