I have a leak and need help!
yep he said it. if you know for sure its coming from BEHIND the covers then those are the options. if its below that it could be the oil pump or filter mount. if you have leaks there i would imagine the whole engine needs re-sealed and your rear main also likely has a leak. big or small you wont know untill tear down.
the good part, these motors are super easy to pull, to seal maybe not so much but not bad..
