Sandrion Posted November 23, 2014 Share Posted November 23, 2014 I've got an oil leak on my '93 Loyale. 3spd, auto, 2wd sedan. EA82 motor, 93,000 miles. It seems like it is leaking from behind the timing belt covers? Any insight into what this could be? Link to comment Share on other sites More sharing options...
skishop69 Posted November 23, 2014 Share Posted November 23, 2014 Cam seals, cam towers, crank seal..... You're going to have to pull it apart, clean it up, run it and see. Link to comment Share on other sites More sharing options...
AnotherGL10guy Posted November 25, 2014 Share Posted November 25, 2014 yep he said it. if you know for sure its coming from BEHIND the covers then those are the options. if its below that it could be the oil pump or filter mount. if you have leaks there i would imagine the whole engine needs re-sealed and your rear main also likely has a leak. big or small you wont know untill tear down. the good part, these motors are super easy to pull, to seal maybe not so much but not bad.. Link to comment Share on other sites More sharing options...
tabletop Posted November 25, 2014 Share Posted November 25, 2014 Might want to check for blowby first though, and the PCV valve for proper function. From experience. Link to comment Share on other sites More sharing options...
Sandrion Posted November 25, 2014 Author Share Posted November 25, 2014 Thanks for all the insight guys, I have no problem tearing into anything, its what i do for a living. This should be fun! Link to comment Share on other sites More sharing options...
