no back up lights '97 legacy
Ok this thing is driving me nuts, switch works, checked the sockets, fine, trying to trace the wires back, my haynes manual shows everything except the backup switch, unless I'm missing something . Theres no power at the plugs where the sockets plug in so I'm figuring there has to be a break where it comes thru the hatch door. Any other thoughts. Maybe I should just pull the motor and put it in the '95 this thing has been more hassle than what its worth.
Edited by rusty97
Not trying to be rude, but you are testing this with the key on, correct?  The back-up lamps will only receive power with the ignition on.  I ask because I've spent an hour plus trying to diagnose a rear defogger, before I realized there way a switch that shut it off when the hatch was open.
If that's good, and you don't have power at the switch, then start going backwards.  If the fuse okay?  Can you trace the wires at all?  If you find that it is an open between the fuse and the connector, it may be easiest to find a place to splice into the wire, and run a new one.
