Suitua Posted November 24, 2014 Share Posted November 24, 2014 Hello, it's my first post here on USMB. Apparently I have a bad inner CV joint on the front right side CV axle. I was wondering if you can take the whole axle from a 89 carbed Loyale (I think its GL) and swap it into my 87 Turbo Coupe. More details: Donor car: 1989 Loyale Carbureted 5 speed manual trans with a HI 4 wd / LO 4wd / 2wd selection Recipient: 1987 Loyale Multi Point Fuel Injection, Turbocharged 5 speed manual trans with a push button 4wd As you can see, the transmissions are quite different and I have no idea if the CV axles are interchangeable. Link to comment Share on other sites More sharing options...
Dee2 Posted November 24, 2014 Share Posted November 24, 2014 This chart may help you http://www.ultimatesubaru.org/forum/topic/73038-axle-replacement-for-ea-series-cars/page-2?do=findComment&comment=629117 Link to comment Share on other sites More sharing options...
Suitua Posted November 24, 2014 Author Share Posted November 24, 2014 This chart may help you http://www.ultimatesubaru.org/forum/topic/73038-axle-replacement-for-ea-series-cars/page-2?do=findComment&comment=629117 Thanks for the quick reply. Looks like it won't fit then. Link to comment Share on other sites More sharing options...
john in KY Posted November 24, 2014 Share Posted November 24, 2014 Won't fit. The inner diameter and spline count are wrong. Link to comment Share on other sites More sharing options...
