mrawrench Posted November 24, 2014 Share Posted November 24, 2014 I've just removed the engine from this 03 outback wagon and the torque converter came out with the engine. It pulled a tube that seems to be connected to the pump out about 6 inches before I could get it disconnected from the converter and then the tube slid back into the trans. The converter slides onto the shaft but does not go in as far as it should. My question is what am I dealing with here? The tube has 2 notches on the front for the pump drive but doesn't seem as if it is bottomed. Is the pump at the back ot the trans or what. Hoping for any information. TIA awrench Link to comment Share on other sites More sharing options...
mikaleda Posted November 24, 2014 Share Posted November 24, 2014 Keep turning it and it will slide on the rest of the way, I beieve its supposed to click in three steps Link to comment Share on other sites More sharing options...
CNY_Dave Posted November 24, 2014 Share Posted November 24, 2014 tHE CONVERTER WHEN SEATED (oops) should look like it is ready to scrape the back of the bellhousing. If you put the engine and trans together the converter must NOT be touching the flexplate when the bell housing and engine are fully mated. If you mate the engine and trans and the converter is touching the flexplate and you pull them together with the bolts... bye bye pump! 1 Link to comment Share on other sites More sharing options...
AdventureSubaru Posted November 24, 2014 Share Posted November 24, 2014 I've measured the last 2 torque converter seatings that I've done. If you measure from the starter hole of the bellhousing, you should have about 1/8 of an inch gap between the TC and bellhousing. The bolts between the flexplate and TC actually draw it forward after the engine is mated to the trans. That tube attaches to the torque converter by way of a C-clip. If it slid back into the trans without being attached, the converter wont seat all the way. (Same thing happened to me once.) Get a flathead screwdriver or three and start fishing for the tube. Pull it out, find where your clip fell and reattach it to the converter. Then slide the whole thing back in gently. Support the center of the torque converter with a finger while spinning it colckwise. if it's lined up it will slide in with a series of three little "clunks" Check your distance between bellhousing and TC and it's seated. Sounds complex but it will all seem simple after it's done. Link to comment Share on other sites More sharing options...
angerthis Posted November 25, 2014 Share Posted November 25, 2014 The best way to put the torque converter back in Is to pull that long shaft out of the transmission There is a little metal clip that has to connect the shaft to the torque converter and then you put the shaft and torque converter in all as one unit than tern it like one full turn if that it will go right into place Link to comment Share on other sites More sharing options...
mrawrench Posted November 25, 2014 Author Share Posted November 25, 2014 Thanks for all the replies. Everybody said much the same thing and it all makes sense. If I have any more trouble (which I doubt) I will repost. Link to comment Share on other sites More sharing options...
mrawrench Posted November 25, 2014 Author Share Posted November 25, 2014 I am unable to reinsert the converter. The only thing I can see that is preventing it from going all the way into the case is that the stator spline inside the converter is off center when I look down the shaft of the converter. Is there some way of centering it? TIA Link to comment Share on other sites More sharing options...
AdventureSubaru Posted November 25, 2014 Share Posted November 25, 2014 You have the tube out and clipped to the TC? If so there should be nothing blocking it. Are you holding the TC level while you spin? If not, it wont line up all the way. Lift the face a bit with one hand while spinning with the other. Link to comment Share on other sites More sharing options...
mrawrench Posted November 25, 2014 Author Share Posted November 25, 2014 Dear subaru fanatic! I have done just as you said. The trans is in the car and the car is on a lift with the trans supported, as nearly level as it will get. when the TC assembly is slid into the case, it goes down smoothly and seems to engage the pump. The tube is mounted on the TC with the C-clip. I have spun the TC while supporting it, pulled it out and tried again about 20 times but it will still not go in all the way so that the TC is below the surface of the bell housing. It is blocked solid and I am at an impasse... What am I missing? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted November 25, 2014 Share Posted November 25, 2014 Not 100% sure that it needs to be below the surface. Have you measured from the starter hole to the TC? 1/8 of an inch is seated. 1/4 inch is not. Link to comment Share on other sites More sharing options...
mrawrench Posted November 25, 2014 Author Share Posted November 25, 2014 My Dear Subaru Fanatic, After my last post I went back and started all over again and Voila! the TC just fell in. Just for the record it is just below the surface of the bell housing and 1/8" from the starter hole. Thanks again (and again) for the help and the patience. Link to comment Share on other sites More sharing options...
CNY_Dave Posted November 27, 2014 Share Posted November 27, 2014 The magic is often in supporting the TC weight right at the button on the front, then spinning it. Link to comment Share on other sites More sharing options...
