rewsiffer Posted November 25, 2014 Share Posted November 25, 2014 (edited) Howdy, I've looked but I can't find a straight answer. I just replaced my left rear wheel cylinder and line. Do I need to bleed all 4 brakes or just the front right and rear left because they're on the same circuit? Thanks. Edited November 25, 2014 by rewsiffer Link to comment Share on other sites More sharing options...
superpoo93 Posted November 25, 2014 Share Posted November 25, 2014 (edited) The search on the site can difficult at times. Please search Google, You will find your answer.... Edit:I found it right away...just saying Edited November 25, 2014 by superpoo93 Link to comment Share on other sites More sharing options...
DaveT Posted November 25, 2014 Share Posted November 25, 2014 Bleeding the 2 on the circuit should do it. If it doesn't , bleed the other 2. Probably wouldn't hurt to replace all the fluid anyway, unless you did so recently. Link to comment Share on other sites More sharing options...
rewsiffer Posted November 25, 2014 Author Share Posted November 25, 2014 As it stands, the brakes work but are way spongier than before. I can brake hard but I can't lock the wheels. I will try all 4 wheels. Link to comment Share on other sites More sharing options...
Leeroy Posted November 26, 2014 Share Posted November 26, 2014 I must say try some Speed Bleeders! They make bleeding the brakes too easy, especially by yourself: http://www.speedbleeder.com/ Link to comment Share on other sites More sharing options...
Subruise Posted November 26, 2014 Share Posted November 26, 2014 put clutch in when bleeding an old soob......because hillholder Link to comment Share on other sites More sharing options...
