keelang Posted November 25, 2014 Share Posted November 25, 2014 Hey first post on this forum, So I have a 96 outback recently changed the back right Tyre with the thinner spare after that when accelerating from rest the car would pull to the right and it would be harder to accelerate, if I'm right this means that it was sticking?(not sure if it's the cause). But all of a sudden out of nowhere I heard and felt a banging on the front right hand side of the car, it is almost as if something is jammed somewhere but can't see it, it happens when the engine is in gear, neutral and off and rolling. Can drive but after a few rotations the banging gets louder and can feel the resistance and vibration more so. Can anyone help me with this who has had a similar problem? If so how do I fix? Cheers Link to comment Share on other sites More sharing options...
lmdew Posted November 25, 2014 Share Posted November 25, 2014 Auto or Manual Trans? If its an auto, you should have put the FWD fuse in when you put on the spare on the rear. I suspect you have taken out one of the CV joints on the half shaft. Link to comment Share on other sites More sharing options...
mikaleda Posted November 25, 2014 Share Posted November 25, 2014 Sounds like torque bind broke somethung, sounds like CV shaft was the weak point. STOP DRIVING IT. If its an auto you can put the fwd fuse in and limp it home Link to comment Share on other sites More sharing options...
keelang Posted November 25, 2014 Author Share Posted November 25, 2014 Sounds like torque bind broke somethung, sounds like CV shaft was the weak point. STOP DRIVING IT. If its an auto you can put the fwd fuse in and limp it home It's an auto, but how would putting a fwd fuse help now considering it may be the front shaft that's broke? How easy to fix? Link to comment Share on other sites More sharing options...
mikaleda Posted November 25, 2014 Share Posted November 25, 2014 The fuse will stop the tourque bind from causing more problems, but if the axles broke its going to need to be trailered home Link to comment Share on other sites More sharing options...
keelang Posted November 25, 2014 Author Share Posted November 25, 2014 (edited) It's definitely not drivable without making a huge racket, how to fix? take the front drivers side cv off, see if its broke, if it is get a new one, do a wheel allignment?? Edited November 25, 2014 by keelang Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 26, 2014 Share Posted November 26, 2014 (edited) wheel alignment probably not necessary. Inspection may be all that is required - compare sides to each other for appearance, how solid/loose the axles feel when shifted about. if the boots are torn, if wheels rotate without the inner cup of the axle turning, etc. If nothing is clear - probably best to have a professional take a look. Tires MUST be the same size/brand/model and close to each other in wear for regular use. For use of emergency spare - check the manual for the car, many models need use of the FWD fuse if automatic, other speed/distance limitations for manual trans cars. Edited November 26, 2014 by 1 Lucky Texan 1 Link to comment Share on other sites More sharing options...
idosubaru Posted November 26, 2014 Share Posted November 26, 2014 1. Does it still have the spare tire on?***Get matching tires on it ASAP 2. What's the history - the car ran great since the day you bought it 20 years ago - then one random day started doing this? or it's gradually gotten worse over time? 3. are the CV axles original? 4. are you still driving around with the same spare tire on? It's probably the wrong size? 5. what does it do if you insert the FWD fuse? you've given us really limited information...you're expecting too much without giving enough descriptive, historical information. Link to comment Share on other sites More sharing options...
keelang Posted November 27, 2014 Author Share Posted November 27, 2014 wheel alignment probably not necessary. Inspection may be all that is required - compare sides to each other for appearance, how solid/loose the axles feel when shifted about. if the boots are torn, if wheels rotate without the inner cup of the axle turning, etc. If nothing is clear - probably best to have a professional take a look. Tires MUST be the same size/brand/model and close to each other in wear for regular use. For use of emergency spare - check the manual for the car, many models need use of the FWD fuse if automatic, other speed/distance limitations for manual trans cars. I have already compared sides, driver side is slightly looser than left, no boots are torn from what i can see. There is no damage externally, I'm guessing it's the joint, i know it is the driver side that is broken, as i had a friend look at the inner cup while driving, the banging happens when the joint slightly jolts/vibrates. Nobody told me about the spare when i bought it, i knew it would be unbalanced but figured it would be ok, didn't think about it at the time. Link to comment Share on other sites More sharing options...
keelang Posted November 27, 2014 Author Share Posted November 27, 2014 (edited) 1. Does it still have the spare tire on? ***Get matching tires on it ASAP 2. What's the history - the car ran great since the day you bought it 20 years ago - then one random day started doing this? or it's gradually gotten worse over time? 3. are the CV axles original? 4. are you still driving around with the same spare tire on? It's probably the wrong size? 5. what does it do if you insert the FWD fuse? you've given us really limited information...you're expecting too much without giving enough descriptive, historical information. 1. Tire being fixed, not moving it haven't for the past 3 days. 2. I bought the car a couple of months ago, but it didnt happen until the spare tyre was put on. 3. CVs are original as far as i know, what if i put 1 after market on and have the original on the otherside? 4.no 5. Havent tried it, but im guessing it would be the same but the brakes wouldn't stick. Also car's had a popped cylinder for since i bought it but i drove it 3000km from Cairns to Melbourne no problem. Edited November 27, 2014 by keelang Link to comment Share on other sites More sharing options...
lmdew Posted November 27, 2014 Share Posted November 27, 2014 Always good to read the owners manual, the FWD fuse info is in there. Half shafts are pretty easy to change as long as the splines in the hub are not rusted in. Loosen the axle nut Pin punch the top strut bolt for alignment Remove the top lower strut mount bolt Loosen the lower bolt Remove the inner half shaft roll pin and slide it off the trans shaft Remove it from the hub. Reinstall in the reverse order 1 Link to comment Share on other sites More sharing options...
Gloyale Posted November 27, 2014 Share Posted November 27, 2014 5. Havent tried it, but im guessing it would be the same but the brakes wouldn't stick. FWD fuse and spare tire have NOTHING to do with the brakes. I suspect if you put the FWD fuse in then the car would not drive with a broken front axle. Link to comment Share on other sites More sharing options...
keelang Posted November 27, 2014 Author Share Posted November 27, 2014 FWD fuse and spare tire have NOTHING to do with the brakes. I suspect if you put the FWD fuse in then the car would not drive with a broken front axle. You're probably right, but that's not what i meant, when i put the spare on in 4WD there was an imbalance in the driver side causing the front driver side to have more power/torque than the rear causing the brakes to stick and the car to drive to the right. Link to comment Share on other sites More sharing options...
mikaleda Posted November 28, 2014 Share Posted November 28, 2014 (edited) You're probably right, but that's not what i meant, when i put the spare on in 4WD there was an imbalance in the driver side causing the front driver side to have more power/torque than the rear causing the brakes to stick and the car to drive to the right.That's tourque bind, nothing to do with your brakes. The one smaller tire caused the rear end to put power to that tire, esentialy changing the gear ratio making the front end fight the rear end. which makes it pull to one side or the other. Edited November 28, 2014 by mikaleda Link to comment Share on other sites More sharing options...
keelang Posted December 3, 2014 Author Share Posted December 3, 2014 Okay so i replaced the front driver side axle with much difficulty, and fixed tyre, but sound is still there is it likely to be the gear box or transmission? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 3, 2014 Share Posted December 3, 2014 consider pulling the front diff's drain plug to inspect for large pieces of metal. If you have a clean container - the diff oil can be reused but, if the oil is more than 2-3 years old, consider new oil. 2 Link to comment Share on other sites More sharing options...
mikaleda Posted December 3, 2014 Share Posted December 3, 2014 Hopefully the tourque bind didn't cause more damage than just an axle. I would check the rest of the axles and the driveline, if that all checks out the I would check the front and rear diff out. Link to comment Share on other sites More sharing options...
keelang Posted December 4, 2014 Author Share Posted December 4, 2014 Hopefully the tourque bind didn't cause more damage than just an axle. I would check the rest of the axles and the driveline, if that all checks out the I would check the front and rear diff out. It's strange because I rolled the car without the front drivers axle and the sound was gone.... the front diff looked fine, well should the ring around it be perfectly circular around it? Link to comment Share on other sites More sharing options...
mikaleda Posted December 4, 2014 Share Posted December 4, 2014 It's strange because I rolled the car without the front drivers axle and the sound was gone.... the front diff looked fine, well should the ring around it be perfectly circular around it? The car won't make any sounds just by pushing it. I'm not sure what ring your talking about though Link to comment Share on other sites More sharing options...
keelang Posted December 5, 2014 Author Share Posted December 5, 2014 The car won't make any sounds just by pushing it. I'm not sure what ring your talking about though Well yes when both axles were on it and it was in neutral it would going forward and backwards and when i took it off it was fine. Link to comment Share on other sites More sharing options...
capn_r Posted December 5, 2014 Share Posted December 5, 2014 With an axle out you are only turning the differential gears but with both you are turning the ring gear as well (you may call it the crown wheel or?) I would pull the plug as suggested above and you will probably find some chunks. Link to comment Share on other sites More sharing options...
