Quick timing belt question, did I screw up?
was doing the timing belt on my 97 EJ22E. Didn't even think to put a cam gear holder on and as I removed the belt the left can gear spun about 20 degrees. As anyone knows who's done these before the left bank is on compression in that position, so it forces the cam either way about 20 degrees. What worries me is that 97 is (arguably) the first year for interference motors. Does that amount of movement have the potential to bend valves?
After it moved the first time I put a socket with a breaker bar on the cam gear bolt and zip-tied the breaker bar to the AC compressor bracket to prevent further movement.
Engine is on a stand. Can spin it with a breaker bar on harmonic dampener bolt, but don't want to now in case there's damage.
