tedbull Posted December 4, 2014 Share Posted December 4, 2014 I want to build some box tube bumpers for the 90 loyale. I can't seem to find the time to pull the stock bumpers and take measurements. Anybody happen to have a solid works drawing for a pair of front and rear off road box tube bumpers? Link to comment Share on other sites More sharing options...
tedbull Posted December 5, 2014 Author Share Posted December 5, 2014 Does not have to be solid works. Can be any kind of sketch or diagram. I realy just need the measurements of the mounting brackets. No time to pull my bumpers to measure. If I can get the measurements I can start fabricating bumpers at work. Link to comment Share on other sites More sharing options...
ezapar Posted December 5, 2014 Share Posted December 5, 2014 Those bumpers come off with what, 4 bolts. Probably about 10 minutes of your time, same time you spent typing up this request. lol You gotta pull them off to make your bumpers, just kill two birds. 1 Link to comment Share on other sites More sharing options...
tedbull Posted December 5, 2014 Author Share Posted December 5, 2014 The time spent typing my comment was done at work. Back bumper sure, simple. My front bumper not so much. Since I dropped the cross member the valve covers are right in the way of pulling the bolts. Not even two universals would get me in there. Going to have to drop the cross member, or lift the motor off the cross member. Anyways, haven't had the time to pull the bumpers Since I work long days. But I do have time while at work to fabricate. Figured somebody had a drawing or sketch they could shoot me. Link to comment Share on other sites More sharing options...
El Presidente Posted December 6, 2014 Share Posted December 6, 2014 You shouldn't have to do anything with the motor to get the bumper off. IIRC the bumper is held on by 4 bolts(14mm?...might be 17mm) right above the rectangle subframe that the front engine crossmember bolts to. its just behind the radiator, well in front of the valve covers. There are captive nuts on the inside of the engine compartment, the bolts come out towards the outside of the car and the heads of the bolts are accessed inside the forward wheel well. If you still have your liners in the wheel well, you'll need to pull those out. Its really not hard, I think you might be confusing it with something else. I find it a lot easier to build things like bumpers, skid pans and any other armor directly on the rig. Things have a way of getting tweeked around and with unibody rigs, the distance between mounting points can depend if it was made on a Wednesday or a Friday. I know you don't wanna hear that because you want to fabricate stuff at work, but there is very little that I would feel comfortable fabing up away from my rig with out taking a ton of measurements. It was good to wheel with you up to walker valley, are up for going to reiter sometime? I haven't been there since it reopened. Josh Link to comment Share on other sites More sharing options...
Gloyale Posted December 6, 2014 Share Posted December 6, 2014 Bumper bolts are way in front of the valve covers. Take out the rad fan and it's easy to get to them. 4, 14mm headed bolts and the 2 connectors for the turnsignals..... Pretty easy if you want to do it. Link to comment Share on other sites More sharing options...
Gloyale Posted December 6, 2014 Share Posted December 6, 2014 You shouldn't have to do anything with the motor to get the bumper off. IIRC the bumper is held on by 4 bolts(14mm?...might be 17mm) right above the rectangle subframe that the front engine crossmember bolts to. its just behind the radiator, well in front of the valve covers. There are captive nuts on the inside of the engine compartment, the bolts come out towards the outside of the car and the heads of the bolts are accessed inside the forward wheel well. If you still have your liners in the wheel well, you'll need to pull those out. Its really not hard, I think you might be confusing it with something else. You';re describing EA81 car.......>EA82 cars the bumper bolts are accessed in the engine bay.........the captive nuts are in the bumper rail. 1 Link to comment Share on other sites More sharing options...
tedbull Posted December 6, 2014 Author Share Posted December 6, 2014 (edited) I Have Had The Front Bumper Off A Couple Of Times and never had an issue. Now that it is lifted and the sub frame dropped the motor is in the way. I dropped one socket in the tube frame already. I will find a way.I can't fab the bumpers on the rig, I don't have a welder or a band saw at home. But I have everything a guy could need at work. And I get material for scrap rate from work. So I guess I was in a hurry, tired, or just distracted when I tried to pull the front bumper this last time. I was looking too far back and going for the large holes in the frame rail, like the rear bumper. But I just looked just now and see the small 14mm bolts up front. Edited December 6, 2014 by tedbull Link to comment Share on other sites More sharing options...
tedbull Posted December 6, 2014 Author Share Posted December 6, 2014 I am up for a trip to Reiter. I was talking with my buddy "crash" who has helped get Reiter back open and it sounds like there is limited trails that are basically "groomed" with some man made features here and there. I guess they are pretty gnarly, meant for full on rock crawlers. Worth checking out though. I miss Reiter. I also hear great things about Elby, Green mountain, and Naches. Link to comment Share on other sites More sharing options...
ferp420 Posted December 6, 2014 Share Posted December 6, 2014 i dont have any fancy programs but i have a tape and some bumpers off the car mounting hole to mounting hole Link to comment Share on other sites More sharing options...
ferp420 Posted December 6, 2014 Share Posted December 6, 2014 Link to comment Share on other sites More sharing options...
ferp420 Posted December 6, 2014 Share Posted December 6, 2014 this was a great bumper i might put it back on some day Link to comment Share on other sites More sharing options...
ferp420 Posted December 6, 2014 Share Posted December 6, 2014 theres the basic mesurments and some pics of my square tube bumper Link to comment Share on other sites More sharing options...
tedbull Posted December 6, 2014 Author Share Posted December 6, 2014 Thank you. That is what I needed. I like that square tube bumper. Link to comment Share on other sites More sharing options...
monstaru Posted December 7, 2014 Share Posted December 7, 2014 I have built several bumperss for many a Subaru. Unfortunately what you are going to run into , is that the mounting points almost never line up with just measurements. Over the years, the dies they use to press thhe sheet metal get worn, etc.. Bolt holes are hard to line up without doing it on the car. just saying. Cheers Link to comment Share on other sites More sharing options...
Vegablade Posted December 8, 2014 Share Posted December 8, 2014 Yeah like monstaru said, your best bet may be to mock up the mounts and then work out from there. Tack it all together and if it looks good burn the rest in. Its how we did mine and it turned out pretty good. Link to comment Share on other sites More sharing options...
ferp420 Posted December 8, 2014 Share Posted December 8, 2014 i agree those bolt holes are always alittle off best to build the bumper and put it on then mark your holes then remove it and drill them its the only way to make sure its not sitting funny on the car someone in one of these threads sead to leave the mounting pieces as long as posable and add a few more bolt holes to spread the load i like the square tube bummper to ive been thinking about puting it back on but the stinger is alittle small and theres no reciver on it but that wouldent be hard to change i like the function of it more than the one im running now but i think im gona build a hybread of sort between the 2 styles next Link to comment Share on other sites More sharing options...
